Question about Belling BIM60 Microwave Oven
Cut out during heating
My Belling MGC850SS stopped heating mid way through the microwave fuction and now will not heat up at all. Can you suggest posible causes and solutions.
  • Steve Burgess Jul 17, 2007
    Many thanks Tekwiz. Your suggestions have been extremely helpful and informative. As the costs to repair would not be far off buying new, I've decided to scrap it. Can you recommend any decent makes, with stainless steel interior, at least 25L and 850W power
  • 105 Answers
Possible causes include a blown fuse or high voltage diode. A bad magnetron or power transformer are also possible. I recommend taking the oven to a repair facility, or scrapping it & getting a new one. Do not attempt to repair this yourself, as microwave ovens have voltages present inside which are INSTANTLY LETHAL, & there are no user servicable parts inside.
Posted on Jul 16, 2007
I have a GE profile PEM31SM3SS that heats intermittently. This is the second time it has stopped heating but in the past has started to work again sometimes months later. Is there any fix I can do short of...
do this test and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Nov 08, 2013 | GE Profile 1.1 Cu. Ft. Mid-Size Microwave...
The ovens in my belling classic ninety deluxe will not heat beyond 110 degrees. what is wrong with it?
Probably thermostat is faulty.
Employ a Belling Approved appliance engineer to check and replace it if in needs replacing.
Jan 04, 2011 | Belling Microwave Ovens
My belling microwave oven will not heat up even though it still powers up. I bought it 3 years ago and is in perfect condition otherwise. A week before it stopped functioning, I accidentally left it on for...
Leaving the unit on with nothing inside probably was the cause of the current failure. What happens is RF reverse flows into the magetron and causes the power diode on the capacitor to fail or the capacitor itself fails. This is not a difficult or expensive repair. IF by chance you attempt self repair make sure the unit is unplugged and that you ground the capacitor 3 times before prceeding with any testing.
You disconnect one end of the diode and read across the terminals. One direction it will read like a wire and the other it will read open. (Good) If it reads continuity in both directions it has failed. If it reads open in both directions it has failed.
Checking the capacitor you simply probe across the terminals with a meter watching for a jump on the meater EACH time the tests leads are REVERSED. No Jump leads reversed = bad capacitor.
I tried looking up parts for Belling in UK but was unsuccessful. You can get a replacement diode or capacitor from any appliance parts source. They are NOT brand specific. Just take your old part with you if you find one of them defective.
Thanks for choosing FixYa.
Aug 24, 2010 | Belling BIM60 Microwave Oven
Microwave blows fuse in microwave mode grill function ok
It is most likely the capacitor has shorted or the rectifier has shorted. Check with ohmeter, but make sure it is discharged first by shorting the capacitor with a wire.
May 21, 2010 | GE Advantium 120 Convection/Microwave Oven
Changing the interior lightbulb of Maytag #MMV5207BCW over the range microwave? How the #$!% do you get the cover off to change the bulb?
I have a belling combi microwave, the covection oven works well but the microwave oven has stopped heating the food up and also the defrost isn't working ? Any tips or does it need repairing and wat are the costs?
Nov 24, 2009 | Maytag Appliances Over-the-Range Microwave...
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
Stopped working during microwave function
First unplug the unit.
The problem is most likely caused by the thermistor (thermal resistor) failing. This device is located at the outlet vent and will cut power if the unit over heat or catch fire. All microwaves have it. You can test it with an ohm meter. You can get a new one from an electronics store like Radio Shack.
You will have to remove the cover to get to it.
This unit may also have a fuse inside, I do not know if this is the one you changed, but you can look at it. You didn't give a model number so I could not point you to a diagram.
Mar 30, 2009 | Panasonic Microwave Ovens
Microwave Steams Up, Heats Up, and Shuts off!
first of all your mwave needs to be properly ventilated .the problem is your magnetron when heated the thermal cutof switch cutts out power to again when cool.change magnetron
Mar 20, 2007 | GE XL1800 1100 Watts Microwave Oven
Belling BIM60 Microwave Oven Logo
277 people viewed this question
Top Belling Microwave Ovens Experts
William Miller
William Miller
Tim Rickards
Tim Rickards
Are you a Belling Microwave Oven Expert? Answer questions, earn points and help others
