Question about Canon PIXMA MG3120 - Multifunction printer / copier / - 5289B019
Printer not responding
Not recognizing when printer in on line either wirelessly or wired
4 Suggested Answers
Semi-Driver
  • 434 Answers
SOURCE: I have a cannon MP620, when i go to print it says
If this is a new install, make sure the printer driver is configured to the correct port.
Control Panel > Printers > Right click "Properties"
Click Port Tab
If you have used this printer before successfully on your wireless network, try resetting your router or access point.
Posted on Jan 09, 2010
SOURCE: Computer recognizes printer but will not print.
try the following help:
pls. visit this blog....
http://fusionschronicles.blogspot.com/2010/06/printer-is-not-respondingsolved.html
Posted on Jun 17, 2010
davidj5684
  • 104 Answers
SOURCE: my printer is showing up on the network. when I
From what I can tell it looks like this printer does not have built-in wireless networking. I believe you still should be able to print wirelessly, but you would need it connected to a computer via USB to maintain the connection.
Connect the printer to the computer that will stay on and share the printer on your network (this computer must be on your wireless network). Go to start menu>printers (win7 says "devices & printers). Right click on the printer you want to share and click "printer properties". Click on the tab that says "sharing". Check the box to share the printer on the network and name it whatever you want.
Now go to the computer you want to print wirelessly. Go to printers again then "add a printer". You should see an option for adding a local printer or a network printer. Choose a network printer and it should search your network and find the printer.
Posted on Mar 01, 2011
Printer doesn't respond via USB only WiFi
As my helper partner states, I quite agree but I would also use a different USB which the one you're using might be damaged, use another USB station cause maybe its also damaged. But if it states that the printer is offline...it will never print because its not selected as your active Printer. Actually you are sending the printing jobs to that printer wich is not active or recognized.
Apr 06, 2014 | Office Equipment & Supplies
Canon PIXMA MG6320 works via USB but not wirelessly
first you must have a links sys.
go to your control panel on your computer and go to view network
status and task, there you can see if your are connected if not set up a new wireless connection.
Mar 05, 2014 | Canon PIXMA Office Equipment & Supplies
Laptop wont recognize printer at all
If would help if you told us the make and model of the printer, and operating system, is it wired or wireless? Then we can see if we can get it fixed.
Dec 05, 2013 | HP DeskJet Office Equipment & Supplies
Reset ESI 2833 until red light turned green. Network Printer still not responding
Check the IP Address of the 2833. I believe there is a gray button you can depress to print out a configuration sheet. If the wireless modem was also your router, you may have a different IP address range and will need to set the 2833 accordingly.
Sep 03, 2013 | Extended Systems Pocket Print Server
My mac doesnt recognize the printer
Hello try to download the latest software from here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=219&lc=en&cc=us&dlc=en&sw_lang=&product=3919448#N197
Please uninstall the old software before you install the new.
Good luck
Dec 11, 2012 | HP Officejet 4500 Wireless All-in-One...
I have a wireless printer and it won't connect. I tried text sopport for the printer and was told that the router needs to be insinck to the mac address . I would like to know if you could tell me how to...
Setting up wireless printers can be such a hassle!
The quickest solution is to let the router sync the mac address itself, don't worry about the details of it all. Easiest way is to start wired, before you go wireless.
When setting up the printer to work with that wireless router, hook your printer up directly to the router/computer the router is connected to. This will allow for the printer/router to recognize each other and establish a connection. Then, when you use a wireless connection (wireless on laptop/ on printer also), they will recognize each other and you'll be able to connect.
This is much less of a hassle than trying to set up wirelessly.
Best of luck!
Mar 15, 2011 | Belkin (F5D5231-4) Router
The wireless canon printer is not responding to the computer.
This means that your system does not display any printer name under the printer's list even though you would have installed your wireless printer on your Windows Vista system. This could be caused if you have not updated printer drivers in your system or the printer is incompatible with Windows Vista. Also see if the Windows firewall is blocking the printer from being recognized by your system.
Feb 28, 2011 | Canon MultiPASS MP360 All-In-One InkJet...
Cant' get wireless printer to recognize Apple IMAC
If your problem is the password, that does not concern the Linksys adapter. Try this http://technicalsupport.blog.friendster.com
Jan 30, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Canon PIXMA MG3120 - Multifunction  printer / copier / - 5289B019 Logo
110 people viewed this question
old marine
old marine
