Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
My lens keeps falling out as my clips fell off.
My clips fell off so now my lens wont stay in. I cant take photos anymore i am very distressed as it was my daughters camera and she has since passed away.Please help!!!! any help would be wonderful....
Try the waranty of the camera and the store wil sent the camera to canon to fix it
Posted on Feb 23, 2009
Took out a axle from my 02 mustang. While removing the c clip the pin fell out instead of staying halfway in. Now i cant get it back in and one of the gears fell off.
The first step to getting a solution would be to post it in the correct section. You have posted this in "Keyboards And Mice"
Mar 19, 2014 | Road Mice 2002 Ford Mustang GT...
My Kodak c190 fell on the ground .. and the lens is slanted now and wont turn on. you cant see the two sides anymore either.. that are ment to open when you turn on the camera.
The repair for this problem is possible, but will probably involve replacing most of the camera, which will easily exceed the value of the camera itself. Your best bet is probably going to be replacing the camera.
Mar 09, 2011 | Kodak Easyshare C190 12MP Digital Camera...
When i turn my camera on it make noise and i believe it from the lens that fell down
If your camera fell down with the lens opens chances are the rings that are around that lens that are used to secure it have been dislodged and are not doing its function anymore. With that fall, however hard it was, you most likely broke other pieces too. the only way to find out is to do a full diagnoses. They will basically take the camera apart, fix the lens and go from there. Contact www.teleplancamerarepair.com , describe what happened, camera details/make/model, and ask for a quote.
important: do not force the lens in or out for that would most likely make matters worse.
More details on the camera here would have helped too.
Jun 23, 2010 | Sony Cyber-Shot DSC-P72 Digital Camera
My wii fell then the game got stuck then the game wont eject i then got it out and it still wont work
when you put a game in your wii, it will lock into your wii with some clips. When your wii fell, the dvd came loose. so the eject button wont work anymore. What you can try, is try to pick the dvd out with a pincet. if that won't work, you should open up your wii and then remove the dvd.
May 17, 2010 | Nintendo Wii Console
Lens Error!
In My case, the lens was coming out part way a start up and pulling back in without camera coming on. Some times the screen would stay a dark blue and could not be shut off. Ensure batteries are new or remove and replace existing. Lens will come out part way and retract when the battery door is opoened and closed. Press "on" button and as the lens comes out touch and hold the lens, with a finger placing pressure on the side of the lens. The lens will stay out. With camera upside down blow into the sliding mechanisms of the lens. Grip the furthest most extened lens with two fingers and pull the lens all the way out with steading pressure. The pressure should be equivalent to lifting one to two pounds of bread with two fingers. Perform this with the camera upside down so that any dirt particles can fall out. A slight rocking (side to side motion) of the lens may help. Once fully extended, open and close the battery door. The lens should retract. Turn on the camera. A couple of ideas relatd to this problem 1) If the concentric circles of the lens are not even, this could indicate a large grain of sand. After lens is extended or partialy extended push the lens on the side where the largest gap is while the camera is upside down. This may provide a larger gap for the grain to fall out. 2) Dirty camera case. I turned my camera case upside down over a piece of white paper and was amazed at the particles of sand that fell out. I turned the case inside out and completely brushed and vacuumed the case.
Jul 13, 2009 | Nikon COOLPIX P60 Digital Camera
Samsung D760 Lens Repair
This camera is probably damaged beyond economic repair - replace it.
Jun 24, 2017 | Samsung Cameras
Memory card not reading (wont stay in place) i9 iphone / phone
I had the same problem but i clipped it back in place, pushed it flat and still holding it flat against the card i slid it back up to lock it. It worked for me.
Feb 13, 2009 | Dual Electronics CECT P168 Cellular Phone
I have a hp m425 photo smart
In what way do you mean broke eg lens shattered or it wont zoom , if its not physically broken  try tapping the lens gently in the opposite direction to which it fell.This should realign the gears
Sep 10, 2008 | HP Photosmart 435 & HP Photosmart 145...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
35 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
