Question about Kyocera Mita FS 3800 Laser Printer
Kyocera FS 3800 printer - error code F3 any ideas!!!!
Error code F3,
Hi i want to print both side but it orinta only one side per paper.for duplex printing what i have to do?
Posted on Jan 29, 2009
  • 350 Answers
Technical Support You may contact Kyocera Technical Support Monday - Friday 9 am - 6 pm EST at:
1-800-255-6482
Posted on Jan 26, 2009
Kyocera 1020 error codes list
Hi Pandirayaj,
I have this manual for you to see errors in Kyocera FS-1020D. Hope it helps.
Kyocera FS FS 1020D Operation Manual Page 37 Error Messages
Apr 25, 2014 | Kyocera Mita FS-1020D Laser Printer
This error indicates a problem with user name, password or domain name. Username/Password or Shared Name/Folder Name. Domain name is not entered.
A complete list of kyocera error codes with description can be seen here:
Kyocera Error codes
Nov 07, 2013 | Kyocera Mita FS 3800 Laser Printer
Error code 7000:0132959
Error 7000 indicates a toner motor error. If you are using a generic toner it could be that the motor is not strong enough to turn the gears on the toner cartridge. Try changing the toner first.
Mar 07, 2011 | Kyocera Mita FS 3800 Laser Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Getting a E2 error on Kyocera FS-1700+. Any ideas?
this service code belongs to Laser scanner unit (Polygon motor) error
check the connection between scanner unit and engine board .....
Oct 06, 2009 | Office Equipment & Supplies
Has an F3 Call service error. Is this a scan head issue? If not what is it? Thanks
You have a defective LASER SCANNER. It is directly under the top cover...you MIGHT be able to take it apart and lubricate the mirror shaft.
Jun 25, 2009 | Kyocera Mita FS 3800 Laser Printer
Call service 7410:0100539 on a Kyocera fs2000d
I have heard that 7410 is a standard code meaning the drum is out of position. Seat the drum correctly and away you go.
David
www.copycare.net
Jan 21, 2009 | Kyocera FS-2000D Laser Printer
PCL Xl Error
when installing new driver choose PS ( post script) instead and see it fixes problem
Good luck
Apr 03, 2008 | Kyocera Mita FS 3800 Laser Printer
Error code on kyocera fs-3800 printer
E1: xxxxxxxx = Main motor error
Either the motor aint turning or it is being stopped from turning...Usally drum or developer units cant turn, or main motor or control board stuffed...
below is stuff from service manual and ....my comments
Suggested causes
The main motor is overloaded. Overcurrent in the main motor circuitry due to an excessive torque....... Check Drum, developer unit, toner cartridge and process units ensuring free movement
• Connector insertion error........check developer plug is secure (left top near toner cart little plug)
• Defective gate array U204 on the engine
board (KP-864). .......replace board
• Defective harness between engine board and
engine relay board (KP-760). .........secure replace cable
• Defective harness between engine relay board
(KP-760) and main motor.
Nov 26, 2007 | Kyocera Mita FS 3800 Laser Printer
Kyocera Mita FS 3800 Laser Printer Logo
413 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
