When i Connect the power cable from ups to the power inlet on the server i get some funny noise. I try to put the machine on, no response.Seems no power getting the machine.
  • Misterixas May 11, 2010
    Is this a noise or beeping?
  • Roberta Smith
    Roberta Smith May 11, 2010
    define "funny" noises
  • 596 Answers
Maybe I am reading this wrong but it sounds like you are connecting the equipment in the wrong sequence. The service is plugged into the back of the UPS unit and the UPS is plugged into a wall outlet. The UPS is a power conditioner/surge protector that keeps your server from being fried if a sudden power surge goes through and it act as a back-up power source if you lose power. Try this new connection sequence and see if you have better luck.
Posted on Feb 03, 2009
Hard drive not recognized
If You are only one HDD connect then you make primary HDD jumper slot sat. And right direction data cable sat. And connect motherboard port proper.
Open Bios and check it HDD driver detect or not. If detect ok if problem then change data cable and power cable. Some diagnosis your problem solved.
Thanks..
Feb 17, 2014 | Intel Hp Proliant Se1101 Server 2x...
When i insert my moden in a laptop gives a response of usb device not recorganised.
If you have another machine to test on try plugging it into it and see if it works. If it does, then on the laptop power it off unplug the power cable, then take out the battery and let it sit for a few minutes, the put battery back in and connect power cable and restart machine. It should start working again.
Jun 13, 2011 | Kingston Computers & Internet
Just bought Brother Printer dcp-j125,After test copy machine says,machine error af. Removed elec cable,plugged back in ,held menu for 15secs.. machine error af,came back on..it makes a funny noise.
Brother DCVP-J125 manual reset
1.plug the power cord while holding the menu with in 16 seconnds to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. press the mono start key several times untill the purge count appears on the LCD.
4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
5. press the stop/exit key to return to the initial stage of the maintanance mode.
6. enter 9 twice by using the up arrow & set key's to exit from maintenance mode
just follow the steps and hope you can do it......
I try it to my self before i post it and shared to others....thnx and GOD BLESS by Harry Technician.
Mar 12, 2011 | Brother MFC 420CN All-In-One InkJet...
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
HP SERVER PROBLEM
You should be using a 110 voltage cable if you are in the USA.
Jun 14, 2009 | HP ProLiant ML350 G5 Server
Connect HP Proliant ML350 Server.
Please verify if your server power specs support 110 or 220 V. If you are in the US, eventhough you might have connected a 220V cable the line voltage can be 110.
Check with your power company if they can provide you the necessary wattage of the server.(Specs are printed on the power supply. you can read it from HP web also)
Once you are sure that, connect both power suppllies and try booting.
If the error still occurs, it can be a power supply failure or some other hardware failure.
Regs,
Jun 14, 2009 | HP Compaq ProLiant ML350 G3 Server
Dmr-es15 "can't read"
after I record a show then I push stop, it writes it to disc and gets up to 96percent and then fails.
Oct 10, 2008 | Panasonic DMRES15 DVD Recorder
Error code SC670
Its an over load of information by the file.
here is the actual code: SC670 mistake Engine Response
Jan 25, 2008 | Ricoh Aficio AP3800C Laser Printer
Cant find the Print Server IP
when you tried to ping the restored ip for the print server did your computer was in the same subnet? if not try to configure your machine ip to be in the same subnet for your print server ip.
Jun 14, 2007 | Hawking HWPS1UG Print Server
Computers & Internet Logo
163 people viewed this question
David Payne
David Payne
