Question about Music
Polarity of dc supply to casiotone MT45
Should pin of ac adapter be + or --
3 Suggested Answers
  • 5603 Answers
SOURCE: I have a Casiotone MT70 made in 1984. How do I
Here is how you might check the polarity of a 7.5 volt DC replacement adapter:
Put the 5 batteries into the unit and verify operation. NOW using a DC voltmeter measure the voltage from battery negative and meter negative connected and meter positive to the pin on the power jack. IF you see 7.5 volts positive, then the pin is the positive lead for the adapter.
If you see zero, then continue testing.
With the 5 batteries inserted, connect the positive meter lead to the positive of the stack of batteries. Now touch the negative meter lead to the pin.
If there is 7.5 volts there, then the pin is the negative lead for the adapter.
READ THESE INSTRUCTIONS CAREFULLY.
USUALLY the jack has a contact that disconnects the batteery when the plug with sleeve is inserted.. We are testing the jack without inserting a plug here so the plug should HAVE THE BATTERY VOLTAGE with correct polarity on the pin.
Posted on Oct 08, 2009
Testimonial: "Very clear explanation for a non-techie to understand. Many thanks."
  • 5603 Answers
SOURCE: My Casio WK-3800 will ONLY work on batteries not
Your adapter should be an AD12M. Some have tried a switching version of this and it has not worked. Make sure yours is the AD12M and not the "ML" suffix one.
The reason is that some of these have filtering built into the adapter, and others do not. The filtering is often required.
Posted on Oct 30, 2010
Replacing ac power adapter.
If the polarity, voltage, and amperage are the same, there is no reason that you cannot use this device as an alternate.
Oct 16, 2016 | Roland Music
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Sep 12, 2013 | Casio Keyboard Power Adapter
Adapter polarity
Boss ME-25, use polarity like boss stompbox.
+ voltage at the ring, and - voltage at the center pin, of the adapter
connector.
At ME-25 DC socket:
Sep 12, 2013 | Boss ME25 Guitar MultiEffects Pedal with...
The power on my banshee is coming on?
Check the polarity of the adapter, if it isn't the original one. Even if you have the right voltage, it still has to have the mA or higher but, most important is the polarity. Most guitar pedals are wired backward on the plug. The positive is on the outside ring of the plug and negative is in the middle. There should be a picture or diagram somewhere on the unit close to the plug to find out. If it is backwards, it could have damaged it, maybe not though. If it is ok, cut the plug off and switch the wires and check it. After all, it's not working now, it couldn't hurt.
Mar 15, 2013 | Rocktron Banshee Guitar Talk Box Talkbox...
What polarity is the input on the ion IED04 DIGITAL DRUM STAION BY ION. I HAD TO GET A POWER ADAPTER AND DON'T WANT TO DAMAGE UNIT. THERE IS NO PICTURE TO NOTE POLARITY.
There is NO POLARITY to worry about since you MUST use an adapter that supplies 9 volts AC at around 850ma. You CANNOT use a DC adapter with this unit and have it work. Putting a DC adapter of 9 volts on it won't damage it, it just won't work.
AC output adapters are harder to find.
Apr 14, 2011 | ION Audio iED04 Desktop Electronic Drum...
Casiotone MT-220 keyboard power cord
I would inspect the unit for corrosion on battery terminals AND the power connector. The connector has a switch when a cord is plugged in, and if this switch doesn't work (they get bent) the unit will not work on batteries.
Best source of power adapters is often your local thrift store.
MATCH the voltage and whether it is AC or DC required AND the polarity if the pin is + or -.
Get one with enough current.
Apr 28, 2010 | Music
Put wrong power adapter into a Yamaha DTXPRESS IV
You should immediately quarantine what you plugged in and compare it to the correct one.
IF you put too low aq voltage of the CORRECT polarity nothing should have happened.
If you put backwards polarity of any voltage the regulator is probably fried internally and possibly an input bypass cap. Also if you put an AC adapter and it wants a DC the same destruction could happen.
if you put too high a voltage, possibly the power input cap may be bad.
It appears that the correct supply is the PA3C which is a 12 volt, 700ma with positive on the center pin.
Mar 29, 2010 | Yamaha Music
I have Yamaha psr 260 and I am connect on 24V, and now speakers dont work. What am I doing?
I believe that is the wrong VOLTAGE !!!
The PSR takes a 12 volt, 1 amp or more DC power supply with positive on the pin.
If you have connected 24 volts either AC or DC of either polarity you have likely caused internal damage. Try a 12 volt DC supply and if it doesn't work, it needs to go to a repair facility.
ALWAYS check the voltage and the polarity on ANY of the devices using the power adapters BEFORE connecting the adapter..
Feb 18, 2010 | Yamaha Music
I have a Casiotone MT70 made in 1984. How do I check the polarity as I need to get an AC Adaptor and don't want to damage the keyboard?
Oct 07, 2009 | Casio Music
Casio keyboard doesn't work with ac adapter
Check the adapter is the right voltage AND polarity for the Casio... I believe they usually take a 9 volt DC adapter with the center pin being MINUS polarity.
Jul 14, 2009 | Music
Music Logo
103 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
