Question about Sony KP-41T65 41" Rear Projection Television
Av channel change
Whilst watching tv the screen will flash to black and the av1 number will appear on screen and the picture comes back. No matter which scart socket is used this will happen frequently whilst watching tv. tried the obvisious i.e checking scarts are connected properly but nothing helps. This has only just started to happen and can't understand why. Any help??
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 60 Answers
Hi, please check if there is enough air flow where tv's ventilation is placed.. Try to keep a pedestal fan close to the tv's air flow holes and check if it happening again.. i think this will mostly solves your problem. If you go with this to your service centre they will simply replace the Tuner,and will give you heavy bill. all the best sreejith
Posted on Jul 16, 2007
SOURCE:
No picture just av1
If the cat sat on the remote, it is likely it changed the tv to AV1. Just find the AV button on the remote and press it again and again. It should cycle through the different AV channels your TV has - my TV has 6 AVs, 2 HDMI and a PC channel so if yours is anything like mine, you may need to press several time to get back to your Sky/freesat/virgin box. Alternatively, some HDMI connected kit just needs turning off and on. That then sends a signal to the TV which changes the TV automatically. For example, my Blu-ray player does that.
Experience - I have a cat that sits on my remote and does the same thing!!
Jul 31, 2012 | Panasonic 37" VIERA Full HD 1080p IPS LED...
What chanel do i put tv on to watch dvd movies
You are trying to work out how to watch a DVD movie on your TV
The DVD should be connected to your TV with Audio Video cables.
And it will most likely be connected to AV1 on your TV
The easiest way to find out would be to
  • Put a DVD in the Player and press play
  • Now the TV is probably in channel mode, so find the button on the TV remote that says TV/AV
  • now press this button TV/AV and it will scroll from TV channel to AV1, AV2 etc until you see the DVD picture.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
Jul 18, 2011 | GPX D1816 DVD Player
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Problem of Audio in Philips TV, Model - 21RF VardanSL
check option bites find it on crt or back cover to enter serv mode coll following comands
062596 menu or display the data will appear select options and set by vol and ch keys
Jul 10, 2009 | Philips 32PW6506 32" TV
Philips 21RF vardaan there is no sound but everything works fine
just open the service manual & change the option to 1-128 ,2- 215 , 3- 065 , 4- 000 , 5- 192 , 6- 129 , 7- 112
By-Rajan
Jul 01, 2009 | Philips 32PW6506 32" TV
#27PT543S37A philips tv model-the tv video channel is not working
In short your tv has a problem on the AV connection, RF using coaxial cable is working okay.
get the tv to the w/shop, let him check the AV panel and AV processing IC.
Apr 30, 2009 | Philips Televison & Video
Sanyo 68cm. AV1 is Black and White. AV2 and normal Tv is OK
the two AV1 and AV2 have different inputs on the IC,
the first port has a disconnection,
take your tv for a check up
Mar 20, 2009 | Sanyo DS13204 TV
INSIGNIA TV FLAT PANEL (not LCD) cant play PS3
Check to make sure it is on either the AV 1 or AV 2 channel
Nov 25, 2008 | Televison & Video
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
Sony KP-41T65 41" Rear Projection Television Logo
53 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
