Where can i get new drive belt?
Belt is too loose and long due to year of use.
  • 356 Answers
Without knowing exactly what CD Player you are having problems with, All I can offer is this link for a possible replacement:
http://www.studiosoundelectronics.com/cdlasers.htm#BELT
Posted on Jan 20, 2013
Honda FG garden tiller 110, stoped running, took it apart, the timing belt loose, what do I need to fix it? Or is it worth fixing?
I'm not aware of them having a timing belt. Do you mean the drive belt? if so, it is supposed to be loose. in the disengaged position. and tight in the engaged position. and to answer your question it is almost always worth fixing. unless you have a lot of money and want a new one. I've seen tillers 30 and 40 years old work just as good as a new one.
Jun 22, 2016 | Honda Garden
Is the drive belt for ground travel supposed to be loose when the brake is off.
It's suppose to stay tight,could be a bad tensioner Brian,give me your year,make and model and I will look it up and send you the repair guide on it.
Aug 23, 2015 | Cars & Trucks
1994 olds 88
tune up time?, at least spsrk plugs, and filters.
misfire is just that. its misifiring and #1 top of list, 100 years is tuneup.
Jul 19, 2014 | 1994 Oldsmobile 88
2000 Nissan Pathfinder, makes loud squeaking noise while driving between 0-35mph, bought a new timing belt a year ago and had AC belt replaced recently, squeaking is so loud it is almost disturbing to...
Very often the power steering belt can cause this noise if it is loose or just worn. The pump itself can cause a noise check and make sure it is full of fluid.
May 06, 2014 | Cars & Trucks
Ariens Hydro ride on mower, Blade Drive Belt will not stay on Pulleys
Are you sure it is the right belt? Is the tightener working properly Are the pulleys miss aligned?
Nov 05, 2017 | Ariens Garden
Harley drive belt wont stay tight after adjustment
Hi Djpiccir, sounds like your axle nut is bottoming on the axle shoulder due to wrong washers or placement of washers. For more information on your problem please visit the website below and good luck. http://www.stcharlesharleydavidson.com/OEMpartfinder.htm#/Harley-Davidson%C2%AE/FLHTCU_FC_ELECTRA_GLIDE_ULTRA_CLASSIC_(EFI)_(2007)/REAR_WHEEL/99456-07B%5CFC/99456-07B%5CREAR%7C~WHEEL%5CFC
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 21, 2012 | 2007 Harley Davidson FLHTCU Ultra Classic...
Does it make sense to need to reset the timing on a car with a 4 year old timing belt?My daughter replaced it at 100K miles when she bought the car...
There is no problem with checking timing due to component wear over time. It is important on alot of engines to maintain a good timing belt due to the fact that many engines have valve interferance. Which means that if the engine were running and belt were to fall off the pistons would make contact with the valves causing damage to your engine. Hope this helps.....
Oct 29, 2009 | 1989 Mercury Tracer
My YS4500 (3 yrs old) has recently been loosing power in the hydro transmission. The engine runs great, but the drive stinks. I have to ease it into drive and as it gets going it will pick up speed, but if...
Yes, what I believe you have, is a loose drive belt. this can be due to several things,1st, the drive tensioner spring may be broken, 2nd,the drive belt tensioner pivot arm may need lube, or the belt is worn out.
You did not mention the hydro making noise(whining) if that were the case i would have you check to see if the brake were sticking.
Sep 23, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Beater Bar Belt loose and bar won't turn
Provided that the motor isn't loose, the belt should fit tightly. If you had reassembled the beater bar back in the vacuum improperly, the belt would be tighter, rather than looser. If you are sure that the motor isn't loose and the beater bar was reinstalled correctly, then either tha belt slipped back off the motor shaft, or they sold you the wrong replacement belt.
Jul 18, 2009 | Hoover U6630-900 WindTunnel Bagless...
Serpentine belt in a 1995 Mercury sable
I have the same car and last night my belt slipped off. The top small pulley backed it's self out. The problem is in most cars the pulleys are reverse threaded so this wont happen, in ours not so much. The pully spins loose with the turn of the belt so it has to be tightened way down. IT's a pain. Here is a diagram I found and You need a 15mm wrench, which doesn't just come in most sets. Good Luck
The book says "Using a 15 mm socket or wrench on bolt attaching drive belt tensioner pulley, rotate drive belt tensioner clockwise. Make sure spring keeper engages into slot." I would put a socket on the 15 mm pulley bolt and a long handle for leverage. Thats one tight spring.
Oct 24, 2008 | 1995 Mercury Sable
22 people viewed this question
 Grubhead
Grubhead
