Question about Toto Aquia II Dual Flush Toilet
How to stop a toto aquia 2 from rocking - Toto Aquia II Dual Flush Toilet
  • 33 Answers
SOURCE: FAMILIAR WITH TOTO AQUIA TOILETS
Everything you need to know about Toto! Hope it helps!
http://www.totousa.com/Default.aspx?tabid=215#
Posted on Jan 27, 2009
kachbibi1
  • 979 Answers
SOURCE: I purchased a Toto Aquia
If this is one of those models that most people have, the valve that shuts the incoming water off when the tank is filled is probably bad. It only costs about 8-10 dollars to replace. This valve is actually a stem or tree shaped device.
Posted on Jan 28, 2009
  • 62 Answers
SOURCE: Looking to buy/install Toto Aquia II in my circa 1964 co-op apt.
When you say 10.5 inches from wall, do you mean that from the center of the drain in the floor to the back wall is 10.5 inches? If so, you need a toilet for a "10 inch rough-in" dimension. The Aquia doesn't come in that dimension. Sorry!
Caroma Sydney Smart model 270 comes in a 10 inch rough-in and is a dual flush model. Note that all dual flush toilets are fairly expensive as compared to normal toilets. HOWEVER, genrally speaking, ALL 10 inch rough-in toilets are fairly expensive just because the low volume that are sold.
Posted on Jul 11, 2009
  • 3640 Answers
SOURCE: REMOVAL OF TOTO AQUIA TOILET
first shut off water and then flush the john. this will remove most of the water. for water remaining in tank us a sponge or similar to remove remaining water. find where toilet bolts to floor and remove these bolts or nuts. then pick whole toilet from floor, there should be a wax ring under toilet, replace wax ring when putting back in. when putting back in just push down on toilet to squish wax ring and bolt to floor, turn on water and check for leaks. good luck
Posted on Apr 19, 2010
  • 122 Answers
SOURCE: What is the best way
here is a link to Toto's website, just click on your model number to download the instruction and installation manual.
http://www.totousa.com/Default.aspx?TabId=75&ProductId=eabca3e6-cdae-427c-bbba-416d4eb453ac&SearchId=17c723a6-5f0d-4ad7-a402-2825882dc50a&PTab=2&STab=1
Posted on Aug 20, 2010
After I flush the water pulses and shakes the pipes,why
washer on stop probably came loose and obstructing flow enough to cause shaking...need to shut water off to house and check the stop undr toilet
Nov 21, 2010 | Toto Aquia II Dual Flush Toilet
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
Apr 16, 2010 | Toto Aquia II Dual Flush Toilet
Toto toilet has weak flush
Check water level in tank and also under rim off toliet bowl where water come's out. Make sure level in tank is right and it has ports all around rim. they can be clogged up also.
You can use a roofing nail to stick in ports it is several around under rim that you can't see but are there where water comes out. Because if the ports some are stopped up it will restrict proper amount of water to certain areas.
Apr 13, 2010 | Toto Aquia II Dual Flush Toilet
Jul 02, 2009 | Toto Aquia II Dual Flush Toilet
I purchased a Toto Aquia II Dual Flush Toilet, around a year ago. No problems until now. The toilet won't flush. It doesn't appear to be running at all.
Jan 14, 2009 | Toto Aquia II Dual Flush Toilet
FAMILIAR WITH TOTO AQUIA TOILETS AT ALL?
Jan 12, 2009 | Toto Aquia II Dual Flush Toilet
Toto Aquia II Dual Flush Toilet Logo
22 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
