Question about Brother XL-5130 Mechanical Sewing Machine
Will not pick up bobbin thread
My sister broke a needle and after I replaced it, it does not pick up the bobbin thread. There is no burr on the hook, and the bobbin appears to be in correctly.
  • nicholem Apr 09, 2009
    help!! I've been sewing with this machine for 5 years and I have sewn a lot.... the thread jammed and the needle broke... after replacing the needle, it will not pick up the bobbin thread... I saw the post about adjusting the needle arm.. but I don't think that would fix the problem, would it?? I would love some help with this...
I am having the same problem with my embroidery machine. I am waiting to hear if it is the timeing. And if i can fix it myself.
Posted on Jan 26, 2009
My brother innovis machine has a problem. Top thread frays and breaks, not not seem to be picking up bobbin thread properly. I have changed the needle tried a previous bobbin.
Be sure to install a brand new needle--check that the needle eye is the correct size for the thread you are using--a small needle eye will shred heavy thread. It may also help to remove the top thread from the machine, ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Try different thread--AVOID old or bargain bin thread. Check that the upper tension is not too tight.
If the top does not pick up the bobbin thread, the machine may be out of time.
Otherwise, there may be a burr or snag somewhere along the thread path that is catching and fraying the thread. Sometimes there is a snag in the bobbin area (possibly the needle plate or hook) that is rubbing the thread.
What Causes My Thread to Shred
Fraying Breaking Madeira
Nov 09, 2017 | Brother Sewing Machines
Does anyone have an idea of what might be wrong with my sewing machine? The bobbin thread is not being picked up by the needle.
rather sounds like the people that repaired it did not check the timing the bobbin has to be in the proper position when the needle passes it so the threads cross over .
Aug 10, 2015 | Singer Sewing Machines
Why wont my Juki DDL-8700 form a stitch?
machine is out of time and u probably have burrs on the hook since you broke the plate with a needle probably from pulling fabric and bending the needle. you instruction manual will tell u how to time machine and its really very simple. all u have to do is take off feeder plate, loosen the 3 screws that hold the hook then lower the needle with the wheel until the needle just starts to rise. bring the loose hook point to i/16 " fron the needle and tighten hook screws. machine must be tilted back to do this whole operation. it helps to have a short screwdriver to tighten the hook screws. remove burrs with lite emory paper stroking in the sale direction as the hook.
Jun 25, 2014 | Juki DDL-8700
When I push the needle up / down button, it does not work., and the machine just squeeks.
some thread might have caught in the metal case on which the bobbin rests. There is a tiny hook in the center that the thread travels around before being picked up by the needle thread to form the stitch. Also, check your bobbin itself. Feel around the outside. If you feel any nicks or burrs, throw that bobbin away and get a new one as the thread is catching on the bobbin itself and throwing the timing off.
Check your needle to be sure there are no burrs or nicks on it. Always use a new needle with each project and if the project is a large one, you will have to change your needle a few times. Needles are not that expensive and make a world of difference in sewing.
One more thing. If your machine manual shows a small "arm" that fits over the bobbin to hold it in place, and that you can remove for cleaning, be sure that it is inserted all the way in and holds the bobbin securely as this will cause the bobbin to "bounce" inside its metal bed and cause the thread to tangle up in the machine.
Jul 20, 2011 | Singer Quantum 9910 Computerized Sewing...
I rethreaded a bobbin and now cannot get the needle to pick up the bobbin thread. What is the trick? Singer Stylist zig-zag 457
make sure that your needle is a good, sometimes there is a slight bend or burr and you do not notice. Replace it and make sure that the flat side of the needle faces the rear of the machine, then hold you top thread end and lower your needle and watch it hook the bobbin thread (when you put your bobbin make sure you have it in your tension slot and there is at least 6 inches) then gently pull your top thread and pull your threads to the back (have at least 6inches or else the needle can unthread.
Aug 30, 2010 | Sewing Machines
Singer Model 6233 While sewing the bobbin cas...
If you broke a needle and cannot get it to pick up the thread from the bobbin you need to check your timing. Remove the needle plate and turn the machine over watching the needle, when it is at the bottom of its travel the hook on the shuttle should be right next to or a fraction from the needle. So that as the needle begins to move upward the hook should pass it if it passes to soon it will miss the loop of thread. Check to make sure your needle is installed all the way up in the bar. If your machine is out of time and you are fairly handy, you can retime it. There should be 2 set screws some where behind the shuttle. Loosen them, one loose and one only as loose as need be to turn the shuttle. The needle must have moved upward about 1/16 before the hook is in place to catch the loop. This can be time comsuming, and you will have trial and error. Good luck. P.S. always check for simple stuff before you go for the hard stuff.
May 20, 2010 | Sewing Machines
Thread is bunching underneath fabric
Needle in correct? Be sure your bobbin is not in upside down and turning the wrong way. Possibly the hook that the bobbicase fits in/on has been hit by a needle and caused a burr that is catching the thread as it comes around. The burr would have to be polished off or hook replaced. The machine could be slightly out of time also.
Feb 10, 2009 | Kenmore 15516 Mechanical Sewing Machine
Broke a needle
Best scenario is that the needle hit deflected and hit the hook that the bobbin snaps on to. When needles hit hooks they can leave a mark or burr that the thread will catch on when it comes around. Take out the hook and run your fingernail over the edge from the point back. If you find a burr get some crocus paper (very, very fine sanding paper and polish the burr off.
Next would be that your machine is knocked out of timing meaning a trech will have to reset it.
Dec 09, 2008 | Bernina Artista 180
When threading my Viking sewing machine., the needle won't pick up the thread. used it 15 years. This is the 1st time this happened. Help...
Do you mean it wont pick up the bobbin thread? You need to get into the user's manual on removing the bobbin shuttle that the bobbin holder clips into (actually pretty easy, I clean ours yearly especially if fuzzy material like velour is sewn) and brush the fixed area out that the bobbin shuttle floats in then reassemble and test. Also remove the throat plate/needle plate and you'll find that fuzz/lint gets between the plat and the feed dogs keeping the dogs from coming up fully.
Also if thread breaks one thing to look for if you've had needles break is a burr around the oval opening in the plate where the needle goes into it. Small Swiss file takes care of the burr and no more burr to break/cut the threads.
On rare occasions you may find the actual bobbin carrier (the one that holds the bobbin and is clipped into the machine) gets worn and wont stay clipped into the shuttle that holds it. Replacing the bobbin carrier is needed then. A1 Sewing on the net carries parts for the #1, #1+ etc.
Apr 26, 2008 | Husqvarna Viking 1
Breaking thread
1. Make sure you are using the correct needle and thread for type of fabric and it is installed correctly. Make sure bobbin is threaded evenly. 2. Tread path - make sure the machine is correctly threaded. Then, with your finger, feel for burrs, nicks or roughness on any metal parts that contact the thread. Open the slide plate, remove the bobbin and inspect the bobbin case and hook. Remove the needle plate and examine the needle hole. Sand any rough areas with fine emery paper and blow away grit. If burrs or nicks remain on the needle, presser foot, needle plate or bobbin case, replace them with exact replacement parts, if they remain on the thread guides, take-up lever, bobbin hook or tension regulator, take the machine for professional service. 3. Loosen thread tension by adjusting tension dial. 4. Clean feed dog, bobbin case, and tension discs. Unplug the machine. Use a small, stiff brush to wipe dirt and lint off the machine head and the needle bar area. Raise the presser foot and the needle to the highest position, open slide plate and remove the bobbin and needle plate. brush away dirt and lint from the feed dogs and bobbin case and remove any tangled thread with your fingers. Use a soft cloth to clean between the tension disc on the tension regulator. 5. Also check tension on presser foot
Dec 31, 2007 | Consew 206RB
Brother XL-5130 Mechanical Sewing Machine Logo
132 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
