Question about Canon DV-MV830i Mini DV Digital Camcorder
5 Grey Horizontal Lines across the screen during play back and distorted sound.
Whenever I playback my CANON MV830 I am get 5 Grey Horizontal lines across the screen and the sound is a bit distorted and snatches of conversation are missing. I have tried cleaning the cassette heads but the problem remains. The problem is there with every tape I try to play despite these tapes playing perfectly before. Please can someone offer a solution. I would be extremely grateful.
  • Anonymous Jul 28, 2008
    sound. problem, and notify you when a new solution is offered.
  • 10 Answers
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Posted on Nov 28, 2008
    Sniper:
  • 60 Answers
Hi, your problem exactly match with the symptoms of dirt in video head,this can prevent the audio also being muted.. If normal head cleaning tape is not of much help to you then you can get it done from the technician. If you are skilled with these kind of equipments ,then open the camcorder door,put some cleaning solution(old spice after shave is good) and gently move over the video head to get it cleaned slowly.. all the best sreejith
Posted on Jul 16, 2007
Unfortunately I cleaned heads and have same problem. It seems my camcorder fell too often on the floor. It looks like some poor contact inside from the head for playback. To get to the head contacts means taking absolutely everything out...a lot of effort...I'll let you know if I handled it somehow.
I thought second reason may be electronical. It happened to me after camcorder was in cold. Not drying out properly (warming up) and switching onb - might have damaged the electronics.
Greetings,
J.
Posted on Dec 26, 2007
  • esardari427 May 20, 2011
    I've just been able to fix the Grey lines problem when I play back video on my DV Camera.
    I tried a mixture of advice:
    -First I ran a Mini DV Head Cleaner through my camera, that actually made things look worse
    -Then I cleaned the head manually with vodka and some fine thread material, that put things back to how they were originally
    -Then I tried to realign the play head by recording on a new tape with the lens cap on for about 3 minutes. I rewound and played back the blackness and it didn't have the grey lines, so I put my old tape in and within 10 seconds the lines all disappeared.
    I'm definitely not a techy person, but somehow with a mixture of advice I was able to fix the problem. Thank you internet!
I have a Canon ZR90A and started noticing horizontal gray lines displaying across the screen when it plays back. What is causing this?
The most common cause of horizontal lines during playback is dirty heads/tape path. If you have a head cleaner tape, try playing it for about 5 to 10 seconds and then try your tape again. Repeat as necessary. Try not to run the head cleaner for long periods of time because you may wear down your heads quicker (cleaning cassette is somewhat abrasive). If you do not own a head cleaning tape, I highly recommend purchasing one. Sony (in my opinion) makes the best miniDV head cleaning cassette. We use this brand in our repair shop and they last for years. I have posted a link to the particular tape I am speaking of. Your local camera/camcorder shop may have these for sale.
http://www.amazon.com/Sony-DVM12CLD-MiniDV-Cleaning-Cassette/dp/B0000632H7
Hope this helps you.
www.austintelstarservices.com
Sep 12, 2010 | Canon Video Cameras
Grey lines during playback.
Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty.
Put video head cleaning tape and playback it as per instructions.
hope this will help you.
Thanks.
Apr 03, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
Horizontal grey bars across screen.
This sounds like it is the Tape recording function that is at fault. Unfortunately, it's also one of the most difficult to correct without a scope and test jig.
However,
If it is more than 5 years old, it may be suffering from component failure.
In particular the Electrolytic capacitors in these small cams seem to fail first due to temperature and humidity changes. They can leak, dry up or corrode, so it may be worth looking inside at the control boards to spot any physical signs of deterioration.
This shows typical surface mount capacitors - silver cylinders with black segment denoting negative -
Sep 08, 2009 | Canon ZR200 Mini DV Digital Camcorder
Grey Lines across video display
Same thing is happening to mine, it's not the minidv because i tried that one on a diffrent camera and it works fine. It's got to be a setting or something. If anyone can figure it out, that would be great.
Sep 01, 2009 | Canon ZR200 Mini DV Digital Camcorder
Grey horizontal lines during playback on camcorder
yes change the tape and also use a head cleaning cassette to clean the cam. chaminda from Sri Lanka
Jun 25, 2009 | Canon MV750i Mini DV Digital Camcorder
Canon mv 830, grey horizontal lines across screen when replaying and a flashing red symdol which looks like a bowl with a slash across it and an arrow pointing down into it
Hi - I have just managed to fix this issue of grey stripes across my screen on playback on my canon mv800 by going into the audio format settings in the menu and changing the format from 12 bit to 16 bit - good luck everyone else! Sharon
Jun 12, 2009 | Canon MV800i Mini DV Digital Camcorder
Horizontal lines on playback screen
Nov 15, 2007 | Canon ZR100 Mini DV Digital Camcorder
Canon ZR200
Hey,
I just started to have the same problem, 5 grey lines and intermittent audio. I the settings and i tried different tapes and No Joy. Then I tried to record onto an old tapes to see if the new recording would do it and the camera showed me a strange icon for exposure. I set the exposure back to 'Easy' and Viola, I recorded and the playback is now clean. Even old tapes play OK now...
The settings must have gotten wacked somehow. I glad it worked out, good luck.
Oct 06, 2007 | Canon ZR400 Mini DV Digital Camcorder
Canon DV-MV830i Mini DV Digital Camcorder Logo
952 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
