I checked out the problem in Device manager and I got this message "This device cannot start. (Code 10)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available."
I checked for solutions and nothing happened. I also tried running an update and nothing happened. I then uninstalled it and restarted the computer and the problem remains. I dont know what eles to do.
Physically take out the drive and reseat it back into place. Then turn the laptop on and go into your bios by pressing F2. If the cd drive shows up in the BIOS then that means the system is seeing it properly. If it doesn't show up in the BIOS then that means the drive is bad and needs to be replaced.
If the drive shows up in the BIOS then reboot the laptop and then once you get into windows try different dvds and cds in the drive. If it reads them then problem solved. If it doesn't read anything then go ahead and clean the laser of the cd drive with a damp q-tip. Clean it and then try different discs again. If it still doesn't read anything then the drive at that point is definitely bad and the drive would need to be replaced.
Click start control panel administrive tools computer
management device manager scroll to cd/dvd rom drives right click properties
then properties again then tick enable cd
digital cd audio for this cd rom device or scroll to dvd regions select
the no _ for your specific area
If this does not fix the
problem you might try
Click start control
panel administrive tools,computer management,device manager scroll down cd-dvd
rom drives you might see a yellow question mark ? right click you will
have options to update driver,roll back driver,or select properties general
troubleshoot, select driver click to reinstall drivers click update
driver or uninstall then reinstall if this does not fix the problem it might be
a registry problem if you cant see your disk drive in windows explorer
Close all open
programs
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug
them back this should activate the found new hardware wizard or
you might have to uninstall
then restart your computer then reinstall your DVD/CD then reinstall the driver
for this device
if your computer came with
a motherboard disk the drivers could be on it
click start control panel
administrive tools computer management device manager scroll down cd dvdrom
drives if you see a yellow question or exclamation mark?! or a red x
right click you will need to update the driver
or
select properties general troubleshoot, select driver
click to reinstall drivers click update driver
hope this helps
The light blinks when i put a disk in but it stops after a couple blinks. The media does not sow up in my computers at all. Dosnt matter if its a CD DVD or Game. I dont know how to uninstall and then reinstall the drive. All i tried was uninstalling it then restarting the computer and it tried to reinstall it itself but there was an error and it didnt install correctly.
i have the exact same problem... any solutions found?
I need some more information??
Does the light on the dvd blink if you insert any media?
Is it getting listed in My computers??
Does it show the media name in My computers??
Did u try to uninstall and reinstall the drive??
