Question about Ariens Garden
Snowblower jumps out of gear - Ariens Garden
Why does my snowblower go slow even using the highest speed/gear.
since we have no clue what kind of snowblower you ask about ill guess you may have grease or oil on the drive disc.
Jul 15, 2017 | Cars & Trucks
Hard to shift gears on mtd snowblower
Start by replacing the cable.
Dec 20, 2016 | Cars & Trucks
Fluid levels in gear box
Amber. With machine on level surface,fill gear box with specified gear oil until it starts running out the fill hole on front of gear box.
press the helpful button and follow me on fixya for more tips
Service
Craftsman snowblower auger gearbox lubricant
Sno Thro Engine Oil Gear Case Lube
Auger Gear Oil Sorry to ask again Snowblower Forum Snow Blower Forums
Feb 09, 2016 | Garden
How do I fix my snowblower when the wheels won,t move ahead or back
Sounds like gear on axle shaft broke shear bolt or key. Take bottom plate off base of snowblower.It is ok to tip snowblown up on front end so wheels are in air. After plate is off turn wheels and see if drive gear is moving with axle. If not key way or bolt has broken off, replace and will be back in motion.
Feb 18, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Snowblower stuck in gear
The issue here is likely related to the "linkage". Linkage is the parts (often a cable or metal rods) that connect the shifter to the actual part(s) inside the snowblower that need to physically move to change speed and direction of the machine.
You'll need to carefully inspect the entire linkage to locate missing or worn cotter pins, bolts, etc. You may need to open the underside on the snowblower to inspect and access the entire linkage. These are typical parts that are used to keep the linkage connected to the shift handle and internal wheel assembly. The linkage isn't usually complex - often a pin or threaded portion that passes thru a hole in an assembly - that is held in place with a cotter pin, bolt, etc. Simply move the shifter so that the linkage can be secured properly and you should be "good to go".
Feb 14, 2014 | Craftsman Tecumseh Snowblower 7hp...
Snowblower always in gear and wont throw snow and cant move when engine is off
Service kit available for that mess of gears in the motor box(needle bearings inside the gear seize up), there is also a shear or sacrificial adapter mounted to the impeller input shaft Parts and Diagrams for MTD 31AS63EF729 2011 check around part # 7 and 15 top right hand corner. hope this helps. if this didnt help check out this web site
Feb 05, 2014 | Garden
Craftsman snowblower won't start
give me more information does it pull by hand or starter ?is ther some thing stuck in the drive gear ?or is it the ring gear turn it by HAnd and see if ya can go backwards with it
Feb 04, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Garden Logo
93 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
