Question about Epson Stylus Photo R220 InkJet Printer
Paper jam im using an r270 for printing pvc id. the printer was ok the first few times. however, when we continue printing using pvc sheets, it's always jammed. we tried using thicker pvc sheets, twas ok but when we use thinner ones, it jams, sometimes though it doesn't. how come?
  • bonna oclarit Jul 16, 2007
    thanks, dodgecharger! i'm gonna try ur suggestion. tho iv tried rubbing the rollers with a damp cloth but its kinda difficult to reach because theyre kinda small and i havent tried opening the top panel.
  • Epson Master
  • 511 Answers
It's normal. Because r270 have good paper sensor at near the head. When PVC sensored by paper sensor, the light not back (memantul) to sensor, so the printer think that no paper.
Posted on Apr 19, 2009
    Novelist:
    Champion:
  • 254 Answers
First, check the entire paper path for anything that would impede paper movement: a small piece of paper, staple, or even a broken piece of plastic from inside the printer itself. The rollers may have become either "slick" due to much use, or they can get covered with dust/paper dust. Cleaning them can help. I'm told rubbing alcohol tends to deteriorate them- perhaps using a diluted window cleaner. There are products sold for this- maybe do a google search on what to use.
Posted on Jul 16, 2007
How to replace paper feeding kit on DCP 7020
Most likely all you need is to clean the rubber feed rollers. Use alcohol.
Oct 24, 2014 | Brother Industries, Ltd DCP-7020 Laser...
My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
How to clear and avoid paper jams
Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
  1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
  • Use only new, unwrinkled paper.
Check paper loading
  • Load a smaller amount of paper into the printer.
  • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
Remove each page as it is printed
  • Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper guides
  • When using media less than 8.5 inches wide
  • To rest against the edges of the paper or media, making sure it does not buckle
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
  • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
Check media loading
  • Verify that the specialty media is loaded correctly.
  • Try loading one page, envelope, or sheet of specialty media at a time.
Check printer default and pause settings
  1. Click:
    • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
    • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
  2. Double-click the print queue device.
  3. Click Printer.
    • Make sure no check mark appears next to Pause Printing.
    • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more of the following:
Clear banner paper jams
  2. Remove the jammed banner paper from the printer.
Review banner printing checklist
  • Use only the number of sheets needed for the banner.
  • Select the following settings to enable the printer to feed paper continuously without jamming:
    1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
    2. Click Properties, Preferences, Options, or Setup.
    3. Select the Paper Setup tab.
    4. From the Paper Size area, select Banner.
    5. Select Letter Banner or A4 Banner as the paper size.
    6. Select Portrait or Landscape.
    7. Click OK.
    8. Click OK or Print.
Regards,
Ron
Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
Im getting an error mp5100, after a paper jam that was removed and the error continues even though I turned the printer off several times
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch
Oct 26, 2010 | Canon Pixma MP480 All-In-One InkJet...
When printing paper continues to jam.
  1. Take out paper tray 1.
  2. Remove any jammed sheets of paper you find there.
  3. Once you have done this, reinstall the paper tray and try printing again.
    Note: You may receive a message informing you that another sheet of paper is jammed elsewhere in the printer. If so, please open the front door and remove the toner cartridge. Also open the rear door of the printer (and the duplex option if a duplex unit is installed). Remove any and all jammed sheets of paper you find. Then try printing again.
  4. If the printer jams again with a 241 Paper Jam error message, look to see if it has tried to feed a sheet of paper out of the tray.
Dec 16, 2008 | Office Equipment & Supplies
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper Jam on
most printers are pretty cheap now so replacement is always an option....on the other hand, I will spend countless hours trying to figure out what is wrong first. Remove all paper first, open printer and check for pieces of torn paper or debris, if you have a can of air you can blow out the insides to clean. Put 3 or 4 sheets of paper in, print a test page and watch carefully how paper advances...is it straight or crooked when being loaded? Is printer trying to pull more than 1 sheet at a time? Good luck
May 14, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Printerjam
A paper jam error message will appear if the printhead is not correctly installed. Try removing and reinstalling the printhead again, but make sure it snaps into place. Try loading a sheet of plain paper and press at the same time copy+cancel; hold them down until the printer feeds the paper. The paper will go through the rollers and come out blank.
Apr 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP PSC 2355 paper jam
I had the same problem. When I inspected the printer inside I detected that on the right sight of the metal thing that's guide te cartridge holder some plactic piece had broken.
When I glued it, everything went OK for a couple of minutes. Because of the presure on that plastic nock it broken again and the same error appeared on the screen.
Sep 21, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP PSP 2355
the only thing that can be done is to go to your printers and faxes folder and looking for your HP printer icon, right click on it and select uninstal, switch off and remove printer from the usb port Next go to add/remove programmes and look for any HP printer software listing and uninstall it and restart the pc. If you have the installation cd that came with the printer reinstall the driver and when prompted reconnect the printer to a usb port preferebly a different one than before if you have spare and continue. reset the HP printer to the default printer if not already been prompted to do so by the software and try again printing, if the result is the same the printer itself is faulty and requires servicing or replacing
Jun 24, 2007 | HP PSC 2355 All-In-One InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
189 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
