Question about Panasonic Lumix DMC-LZ7 Digital Camera
Panasonic lumix dmc-lz7 lens cover won't open
I was using my camera and everything was fine. I turned it off and then saw something else I wanted to take a photo of. I turned the camera back on and the lens cover did not fully open. It opens only a crack. I can push it all the way open with my fingers, but it does not stay open. The camera still functions normally, otherwise--zooming and even taking photos of a crack of light. I've turned it off and on several times but nothing helps. I was on a boat at the time on my off of an island in Thailand. What can I do to fix the problem?
  • maryalice198 Mar 29, 2009
    Lens cover will not open when camera is turned on. I solved the problem temporairly by dusting the external coverings with dry graphite. It worked fine for awhile, but has reverted back to not opening. Tried the solution again to no avail. Stays almost completely closed now, & manually opening it does not work.
Hey how you doin.
I had the same problem during a trip around Australia, some bull dust built up around the lens area. The only thing I did to rectify the problem was to blow it out with a tyre inflator at a road house when I stopped for petrol. No problem since then.
You may have some fine sand wedged in the cover area aswel.
Good luck 'R'
Posted on Feb 04, 2009
I also had this problem, and it was also fixed with a Q-tip. the reason i had the problem is the flaps worked their way intot eh wrong order, like a fan that won't close until all the fans are in the right order.
Posted on Jul 19, 2010
I started poking around the lens cover thing with Q-tips to try to see if there was some way I could figure out how to fix it. I eventually got a little frustrated and just sort of whacked it with the Q-tip and they came open all the way! I turned it off and then back on again and they were still only open a crack. I flicked it again and it stayed open and has opened just fine since then. Hopefully this is a permanent fix to some sort of wonky problem. But realistically, I think it might just poop out at some point. But I'm carrying Q-tips in my camera case now!
Posted on Jan 28, 2009
The lens cap of my lumix TZ7 no longer opens. thank you for the solution.
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Aug 13, 2011 | Panasonic Lumix DMC-LZ7 Digital Camera
Dropped lumix but now everytime I switch it on its tells me to open the lens cover even when it is open.
It shows a problem with the motorized lens mechanism.I will prefer unscrewing the camera only if you are such an expert because there are very fine mechanics inside the Panasonic Lumix DMC-LZ2 which could be easily damaged if mishandled.Please take it to the nearest authorized service center.
I know this is not the solution you were expecting but I won't allow a much bigger damage due to mishandling.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 14, 2011 | Panasonic Lumix DMC-LZ2 Digital Camera
How can I clean the INSIDE of a Panasonic Lumix DMC-LZ7 lens?
Unscrew the entire lens assembly from the body. The inner lens cannot get debris inside it but the outside of it and the inside of the protector lens can. It's a good idea to do this cleaning in your bathroom with the shower on hot but not visibly steamy as this will cut the airborne dust by 90%.
Feb 22, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
Want that my panasonic dmc-lz7 become a webcam but it cannot connect to my pc
The camera is designed to store images and videos onto a memory card, not to stream them live to a computer. It cannot be used as a webcam.
Feb 06, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Panasonic lumix dmc-lz7 lens barrel doesn't move
Hi Sarah I am Vortash it shouldnt need to be a new camera a good clean out by an engineer should cure the problem provided you havent tried to force the lens back in if it was out , he will clean it with white spirit or alchahol and re set the lens mechanism and it shuold be fine .. but get an estimate first as the economics may be in favour of a new camera if it would cost too much .. in the uk here we charge approx $25 for that but it may be more over the pond .. regards Vortash
May 31, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Manual for DMC-LZ7 digital camera
Hi - You can download the manual from the link underlined in blue below:
DMC-LZ7
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 02, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
Lens cover only opens half-way
If the lens barrel isn't fully extending on power up, that will prevent the lens cover shutters from springing open. There is a stationary prong that pushes the cover closed when the barrel is retracted.
Does the camera work otherwise? Take pictures thru the half open lens?
Jun 15, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
Panasonic Lumix DMC-LZ7 problems with lens extention/retraction
Dear I have the same problem with a DMC FX-55! A mess!! Any solution?
Jan 28, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
Panasonic Lumix DMC-LZ7 Digital Camera Logo
737 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
