Question about Electrical Supplies
How to wire my ouellet ofm 1002 to a 120 outlet
How to wire to a 120 volts
Add 12 volt outlet switched by ignition
Look in your owners manual for the accessory fuse. That line turns off. Also, consider a 12 volt relay between the seat and your power source. A small toggle switch will work well for a relay.
Dec 13, 2013 | 2005 Pontiac Montana SV6
Wire 12 volt outlet switched by the ignition
wire it up to the spare in your fuse box. one side is on only when your ignition is on .fitted with an online switch .to switch on and off.
Changed out ofm, so i have a brand new one, but when i kick on a/c after about a min ofm shuts off but compressor still runs. is there something im doing wrong?
It maybe cycleing on a pressure switch. are you certain that the fan is in the same psoition you removed it from this is very important . dowes the fan com back on after s short while ?
Jul 23, 2011 | Heating & Cooling
A diagram of how to wire a 220 volt outlet from two 110 volt outlets.
You can't really do that. The two 110 outlets probably come for the same 'leg' of the 240. If you check them with a meter, there will be '0' volts between the two hot wires. So, they have the same 'potential'. You need a regular 240 volt circuit from a double pole breaker that is rated for the wire size that it's feeding. 20 amp-#12 ; 30 amp- #10 etc.
Sep 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
The outside fan motor (OFM) will not turn off.
it sounds like your fan connector is on the same side of the contactor where your high voltage enters you should have 3 wires 1 wire for each pole of the contactor and 1 wire off the capacitor does the compressor run all the time too? try turning the power switch off on your indoor air handler / gas furnace if the power goes off the fan goes off then it could be low voltage wiring
Jun 30, 2009 | Ruud UAMB Air Conditioner
Wiring a stove
If there is no 220 outlet in the location where you're planning to put the stove then you need to run wiring to the new location. There are two seperate phases of 110 volts coming to your home. The voltage between each of these phases and the neutral wire is 110 volts. When your house was wired only 1 of the 110 volt signals was run to your 110 volt outlets. In order to create a 220 volt outlet you need both of the 110 volt signals run to the outlet.
If you have a straight shot between your breaker box and the location where you need the 220 volt outlet then this is not too big a deal. If you have finished ceilings and walls inbetween then this will be much more difficult.
If you're not comfortable with electrical wiring this would be a good time to call a licensed electrician.
Nov 18, 2007 | Ovens
Electrical Supplies Logo
29 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
