Question about Intel D845GVSR Motherboard
My monitor becomes pink as soon as it starts. Checked the cables ... etc.
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Have you tried it on another system? Same result?
    If it works on another system, it may be your video card.
  • 56 Answers
CHECK THE PIN ON THE MONITOR CABLE ONE IF THEM ARE BENT JUST STRAIGHTING IT OUT
CANDYMANCANDY
Posted on Jan 27, 2009
My monitor has a pink color to it, i.e., I open a word document and the paper looks a very light pink. I already checked the cables and they are not loose. I even took the monitor back to the store for an...
This is most likely a defective cable. I know that you said you checked and it was not loose, but this sounds like the cable is damaged internally. VGA cables are similar to Component cables except all in one bundle, same with HDMI, etc. etc. Try another cable, if you get the same result, the last option will be the Video Card in your computer. If you are using a Video Card that plugs into the Motherboard, (PCI, PCIe, AGP) then you need to make sure that it is FULLY plugged into the slot and not loose. If you have video that is built right into the Motherboard, you may have to replace the Motherboard if none of the other steps have worked. Always make sure you have the latest drivers for your Video Card and Motherboard. Updating your drivers can help with many problems.
Jun 09, 2011 | AOC 917Sw 19" LCD Monitor
Hp w2007 why does the computer go pink everything that is green is now black
All the colours on the screen are created by "mixing" the 3 "primary" colours (red, blue, green).
Once the production of "green" ceases, anything that should be "100% green" becomes "100% black",
and every colour that indicates some percentage of "green" becomes a mixture of just RED and BLUE, i.e., various shades of PINK.
First, try the monitor on another computer (desktop or laptop). If the problem persists, it's time to replace the monitor. If the problem vanishes, it's the video-card in your computer that is not generating GREEN, or it is the "data" cable between your monitor and your computer that is not transmitting the GREEN request. So, you can try replacing the data-cable, or try replacing the video-card.
Jul 11, 2010 | Computers & Internet
My monitor in blurry and has a pink tinge to it. I can click a button on the side and bring up a box that says brightness, contrast, sharpness,etc- but I can't move off the brightness to change to other...
Use the LEFT and RIGHT arrows (or UP and DOWN arrows)
on your monitor to move between the different items (brightness, contrast, etc.)
However, "pink" is generated when your computer tries to generate "white" (mixing red, blue, green) but one of these 3 "primary" colours is not being generated.
Try your monitor on a different computer, to see if the "pink" is due to your monitor, or due to the video-card on your computer, or due to the data-cable between your monitor and your computers.
Dec 31, 2009 | Addlogix Computers & Internet
Monitor turns pink
First I would check the end of the cable that plugs into the computer, if this has become loose, it can cause discoloration. If it isn't loose, unplug the cable and see if any of the pins have become bent on the inside. IF they have become bent, you can usually carefully use a pair of tweezers to slowly bend them straight again (be careful because if you aren't you could break the pin off). If your monitor has the ability to removed the VGA cable from the monitor, you might try replacing the cable (most CRT monitors do not support removing the VGA cable though). Lastly, as this is a CRT monitor, you might need to Degaus the monitor or the electron gun could be coming out of alignment. Most CRT Monitor's have degaus button (usually marked by a symbol of what kind of resembles a horseshoe) which if pressed will degaus the monitor. If your's doesn't have a degaus button, try searching through your menu for the degaus option by hitting the monitors menu button. To see if your electron gun is out of alignment, lightly tap the side of the monitor. If you see the color change, or the color returns to normal, your electron gun is out of alignment and will get worse over time. Buying a new monitor is usually the best option if this is the case.
Jul 31, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
May 13, 2007 | SAMTRON 55V 15" CRT Monitor
Lcd computer monitor
Have you checked out the Comnputer on another Monitor? Are you sure it is the monitor.? Check the data cable some times pins can get bent through rough insertion.
Apr 11, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Intel D845GVSR Motherboard Logo
22 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
