Whirlpool clean touch model LSC6244ANO agitator will not agitate, after we take apart the fabric softener dispenser, how do we take off the agitator?
2 Suggested Answers
the dr
  • 447 Answers
SOURCE: Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Posted on Nov 28, 2007
GE washer model # WHDRR418E4WW : Having trouble removing the plastic cap under the fabric softener dispenser, so I can access the agitator bolt.. There appears to be no simple way to remove it. There are...
that's right just put your fingers under agitator and pull up,under the agitator is a coupler that has a screw in it,whirlpool has the nut in there,if you have a problem with the agitator not moving the clothes around that coupler wears out and has to be replaced.
Oct 07, 2017 | Washing Machines
Fabric Softener Dispenser Broken
Part # 8566491 it runs around $50.00 and it just snaps into place you can find/order at http://www.whirlpool.com/catalog/parts_and_accessories.jsp  Or any local appliance parts distributor you can find in the yellow pages.
Sep 13, 2009 | Washing Machines
How do i disassemble the fabric softener dispenser? already popped off of agitator
This softener cup doesn,t come apart.The easiest way to clean it is to throw it in the wash cycle with rags and hot water. Then from here on use less softner . Mix it 50/50 with water.
Aug 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Fabric softener dispenser not working
If the model number you have this listed under is correct, you should have the softener dispenser on the center post of the agitator. If this is the case, you need to remove it by popping it off the center post and take it apart. Soak it in some hot water to dissolve the softener residue and reassemble. Most dispenser related problems are attributed to softener that hardens and clogs up the dispenser. Liquid softener is essentially a wax and will do this over time. You will need to clean it from time to time.
Apr 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I've had an Amana Washer model ALW880QAW for about 6 yrs. Recently I've noticed old clumps of old detergent and fabric softener in the wash. I've already cleaned the fabric softener dispenser but the...
I couldn't wait for a rely on my posted question on March 6,2009. I was able to ask around to figure out how to clean this up. This Amana washer model has an agitator that is just clipped on. I just got my fingers underneath the agitator and pulled it off. After getting the agitator off, I was able to clean all of the old built up detergent and fabric softner with some old fashion scrubbing. Then I used some CLR to get what ever I missed. I pushed the agitator back until it clicked back into place and ran one washing cylce to clean things up.....Works great....No more old clumpy stuff showing up in the wash....
Mar 06, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
How to pull apart fabric softener dispenser
MOST DON COME APPART SOME HAVE A BLUE RING PUT IT UP AND PULL THE SOFTERNER UP AND PUT IN THE WASHER RUN A LOUD SMALL AND HOT WATER AND LET IT CLEAN IT SELF IN THE WAHSER
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Does the agitator in our machine have a fabric softener dispenser?
softner only ..liguid bleach goes in dispenser on right front corner
Sep 07, 2008 | Whirlpool Washing Machines
Agitator Dogs
take the cap or fabric softener dispenser off the top of the agitator. under it should be a clear plastic cap with a little handle on it. take it out. under it should be a bolt (7/16) with a rubber seal under it, take it out and this will release the agitator and you will see the plastic dogs inside the agitator.
Aug 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Nov 28, 2007 | Washing Machines
Fabric softener doesn't dispense
Fabric softener dispensers are notorious for getting all gummed up and clogged. Remove the dispenser cup and soak in some hot water to dissolve all residue. While you have the dispenser removed check under the dispenser cap in the agitator for gummy residue as well. Clean with hot water. There should also be an agitator seal cap under the dispenser. Make sure the cap and rubber o-ring are seated properly. Last of all, if the dispenser has a cone shaped cup inside, make sure it is inserted cone-side UP. The cup is designed to allow fabric softener to roll down the sides of it, NOT hold it. I hope this helps.
Apr 09, 2007 | Kenmore 24982 Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
