Question about JVC KD-LX1 CD Player
No harness for jvc kd-lx1, require assistance to wire the radio c
Require assistance to correctly wire up the radio to a power supply for testing purpose.
    Scholar:
  • 116 Answers
Don't know the pin configuration off hand, but you can still buy the harness for the Kameleon from JVC. www.jvc.com the link is here
http://www.jvcservice.com/store/ProductDetail.asp?part=QAM0066-002 and it's $22.48 OUCH!!!
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
How to set equalizer for JVC KD-LX1 radio
press select key under volume button then use - button to adjust.
To view a free user manual, you can go here
http://resources.jvc.com/Resources/00/00/99/LVT0223-001A.pdf
Jun 03, 2012 | Car Audio & Video
The memory on my new jvc car stereo model kd-s17 does noty work whenever i turn the key off then on i have to reset the clock and presets all of my wires are connected
need to check the yellow constant power wire on wire harness to see
1. connected to battery with constant 12 volts
2. if wire has power 12 volts
if no power check fuses to see if blown
with out this wire working right you will never have pre set station on radio or clock
with correct time
Dec 22, 2010 | JVC KD-G801 CD Player
Jvc kd-r200 wont power on
you have the red and yellow wire on the radio mixed up switch them
Apr 25, 2010 | JVC KD-G110 CD Player
Connect jvc kd-lh1150 in elantra 2001... different connector
Hello claude_bouth,You need a vehicle specific aftermarket connector generally called a "wiring harness". Your JVC came with a plug that fits the back of the receiver with "pigtail" wires which you splice to the harness wires. http://www.SonicElectronix.com sells the Metra 70-7301 which appears to be the correct harness for your Elantra.You can tap into the wiring of the car harness and splice the wires by function into the appropriate car wires, but using the aftermarket vehicle specific wiring harness is a lot easier and you don't need to disturb the vehicle wiring in any way, just plug into it. It also makes it possible to re-install the factory radio if you ever need to do so. If you choose to tap and splice, you can find your Elantra's wiring color code at http://www.modifiedlife.com.Hope this helps.
Jun 05, 2009 | JVC Arsenal KD-LH1150 CD Player
Jvc car audio KD-PDR51installation problem
Your switched ignition lead is hooked to a constant voltage wire.
You need to find a source wire that is only given power with the key in the on position.
One wire (yellow) on radio goes to a power wire with +12V constant power (regardless of key position)
The other wire (RED) on radio will need to be attached to a Power wire whose supply is only +12V when the ignition is enabled.
Since you are using a wire harness, you just need to reverse the 2 wires as they currently are installed.
Hope this solves one problem anyway.
the wires being reversed on the harness also may not activate an internal relay allowing the steering wheel functions to operate.Switch the 2 power wires, and re-try.
If the steering wheel controls still fail to operate properly, your module may be defective.
Post your results.
Jan 15, 2009 | Car Audio & Video
Wiring my jvc kd-g331 to a 1996 vauxhall corsa
You can go to a place that installs car stereos and purchase a universal wiring harness for your car that will cost about $15 and allow you to do the wiring very easy without the need to know what every wire is for. This harness would be wired to the harness you got from JVC for your new radio and all you need to do is to match the colors of the JVC harness to the same colors of the universal harness that would then just plug right into the factory wiring harness for your car and then the other end plugs into the connector for your JVC radio. It is very easy and insures that you have all the proper wires connected to operate your radio and have full functions available for use.
If you require to know what each wire from the JVC harness is for, just ask.
I would be happy to offer you more help if you need it, just reply to this post and I will get back to you as soon as I am able.
If you found this free information to be useful a FixYa! rating would be appropiate and very much appreciated. After all, it is the only reward we get for helping people like yourself for free.
Thanks and good luck with your radio installation,
Dave
Sep 04, 2008 | JVC Car Audio & Video
Wiring Harness
I had some two conductor wire, which is used generally for alarms or for low voltage items, umm what i would recommend is you can use some of the two con for the Purple positive on your harness, but get something a bit thicker in gauge for the Yellow battery, use something more that would accutaly hold better power that you can use in terms of powering items, you should be able to get away with using something like that sorry if this isnt too much help, best bet is using alternative wires, otherwise try a Radio Shack they might have a Radio Harness or even bestbuy
May 07, 2007 | JVC KD-G210 CD Player
JVC KD-LX1 CD Player Logo
299 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
