Question about Samsung Microwave Ovens
The microwave is displaying S-E AND 7777 and beeping
Model# SMH9151W
This morning my microwave began making 3 beeps every 3 minutes.! I only use it to reheat.
Try unplugging it for a minute, then plugging it back in and trying it again.
If you still need help, contact me. See my profile picture.
Mar 30, 2016 | Samsung SMH9151W 1.5 Cu. Ft....
Why does it display 'Food' and beeps when press 4,5, or 6?
Google (GE)(model)(manual) without parens of course to get the manual you need
Dec 15, 2015 | GE Microwave Ovens
Why is my Samsung microwave model smh9151w showing 5e-1 and beeps
Unless there is grease, moisture, or some other foreign material deposits on your control circuit board, "SE" means you have a shorted membrane keypad.
For the official repair information as per the Samsung bulletin, see http://www.microwavecontrol.com/samsung_se_error.htm
See my profile picture if you need more help.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Oct 05, 2015 | Samsung Microwave Ovens
SMH9151W--se ERROR MESSAGE-HOW TO FIX
The 5E error indicates a problem with the key pad. The microwave computer believes there is a short between the key pad and the central board. You may be able to temporarily reset the error by unplugging the microwave for at least 30 seconds. (In some cases, tripping your circuit breaker may be an easier way to disconnect the power to an over the range microwave.)
Some people have been able to solve the code by cleaning the contacts in the wiring harness. The recommended solution is to replace the assembly control panel (switch membrane, window and control panel). See http://www.searspartsdirect.com/samsung-microwave-parts/model-SMH9151WXAA0000/1482/0123370/50041332/00004.html for a parts diagram and some prices.
Since microwaves have capacitors that store significant amounts of energy, you may want a professional to take apart the microwave and do the repair.
I hope this helps.
Aug 20, 2015 | Samsung Microwave Ovens
How do I fix a SE problem on a Samsung microwave model # smh9151w
Usually that means you have a shorted keypad, and to fix it you usually have to replace the control console/keypad assembly.
Oct 19, 2014 | Microwave Ovens
My SMH9151W Samsung Microwave displays a -SE- or a -5E- and will not operate. I unplugged over night and still will not operate
I had the same issue on a 2010 smh9151w samsung microwave after installing it and using it with no problem for 5 days. The second time we unplugged the microwave and turned the circuit breaker off and on we didn't reset the clock on the microwave so the display shows :0 and it has been working for 7 days straight now. Fingers crossed that this is a long term solution. Hope this helps. Thanks!
Mar 20, 2012 | Samsung Microwave Ovens
The display panel readout has a 5E or possibly a SE on the dislplay constantly
SE error means you have a shorted membrane keypad.
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
We would need the model number in order to provide you with free assistance.
It will be one of these:
SMH9151B
SMH9151B/XAA
SMH9151B/XAC
SMH9151BE
SMH9151BE/XAA
SMH9151S
SMH9151S/XAA
SMH9151ST
SMH9151ST/XAA
SMH9151ST/XAC
SMH9151STE
SMH9151STE/XAA
SMH9151W
SMH9151W/XAA
SMH9151W/XAC
It is usually found on a tag located inside the cooking cavity or around the door frame or controller frame.
Since FixYa is still not notifying us when you respond to clarification requests, you will have to post a new help request with your model number and symptoms / questions, or you may contact us here for this free assistance.
In some cases, it is a simple do it yourself repair.
Sep 18, 2011 | Samsung SMH9151 Microwave Oven
Microwave keypad does not respond and screen reads SE
"SE" error means you have a shorted membrane keypad.
The exact part you need will depend on the model number, which will be one of these:
SMH9151B SMH9151B/XAA SMH9151B/XAC SMH9151BE SMH9151BE/XAA SMH9151S SMH9151S/XAA SMH9151ST SMH9151ST/XAA SMH9151ST/XAC SMH9151STE SMH9151STE/XAA SMH9151W SMH9151W/XAA SMH9151W/XAC SMH9151WE SMH9151WE/XAA.
On some models, you can just order a new membrane keypad and replace it. It's cheap, but a lot of work.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
On other models,
the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job, but it costs more.
Feel free to contact me directly (and please remind me of your full model number) for more information & help and a free estimate for us to do it for you.
Aug 20, 2010 | Samsung SMH9151 Microwave Oven
Fan not working on microwave model smh915
Samsung SMH9151W microwave display shows "-SE-", after power on. Nothing else working. Any idea? Thanks a lot
Aug 03, 2010 | Samsung Microwave Ovens
Microwave Ovens Logo
111 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
