Question about Maxtor OneTouch II external hard drive 500GB 7,200 RPM - FireWire & USB (E04W500)
Maxtor drive partition
How do i partition a maxtor external hard drive?
  • 46 Answers
I'm not sure how you do it with out a program. If you google something like "Partition Editor Program", that may be the best thing for you.
Posted on Jan 26, 2009
My maxtor external hard drive gives a beep sound when I plug it to my computer. The computer says "a new external hard is added to your compute"r but when I click on MY COMPUTER, it doen't...
1) click start
2) right click on "computer" or "my computer"
3) click manage
4) IF you get a user account control popup click yes
5) double click on storage
6) double click on disk management
7) identify your disk, it should be empty and most likely named "disk 1" or maxtor drive or something
8) right click on it and select format (quick format, default allocation size, NTFS)
9) voila!
-Luke
Jul 21, 2011 | Maxtor Hard Drive
I have a maxtor diamond 9 plus used as an external hard drive .I tried to format it .It had 3 partitions .This hdd was originaly from my descktop but with a special cable i transformed it in an external...
By deleting the windows partition, you may have deleted the windows compatibility. You can try and reformat a partition of the drive to a windows FAT32 I believe, but you may lose your other data.
May 04, 2011 | Maxtor Hard Drive
Cannot read my maxtor in the computer
Put the bad drive back in and just like it was. Take the maxtor cd to another computer and make the diag cd. Boot your system from this cd. It's written in linux so it can boot the system. Most of the time this happens when the drive is unreadable. It's caused by the controller chip in the drive thinking the partition is gone. It will tell you to partition and format. If you get the dreaded 006 error then the drive is usless. Get the referance number it says to give the tech. If under warranty then go to maxtor site and fill out the mra forms. This is where you're gonna need the ref number. Maxtor is REAL picky about how you pack it so follow their directions.
if you don't have the cd you can get MaxBlast from their web site.
Jan 10, 2011 | Maxtor OneTouch 4 Mini 160GB External USB...
I have been using my Maxtor external drive for about 3 months without any problems, but in the last week it has stopped working and I get the error message no external drive found or either either the...
Sorry, Maxtor prog on poota is currupted. Have you recently downloaded programmes? When updating, some progs have a nasty side-effct of hitting some other programmes, not all the time,just your important ones?
You will have to uninstall and reinstall Maxtor prog, Not sure there might be a repair facility, not sure but it worth a try before uninstalling all.
Nov 14, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Maxtor basic 1.5tb plugged in but wont run on pc
first you need to format it an need to creat a partition
go to computer mangement by right click on my computer then manage
go to disk mangement here u will find new hard disk create a new partiton and format it. if there is already a partition u need to give it a drive letter or need to activate it
Oct 02, 2009 | Maxtor BASICS Personal Storage 3200...
MY external hard disk maxtor is not detected
Is this a new Maxtor external drive? It came with a CD. Run the utility.
If there is no data on it that you want to save, you can also blow away the partition and format it:
Right-click [My Computer]
[Manage]
[Disk Management]
Find your external Maxtor Disk inthe list and / or graph
Right-click on the disk and select either "Format" or "Delete Partition"
(try format first) Use "NTFS quick format"
If you delete the partition, then "Create Partition" and then format.
You can assign a drive letter or accept whatever it assignes (probably Drive D)
*done*
Sep 30, 2009 | Maxtor / 80GB / 7200 / 8MB / SATA-150 /...
Want to format for pc
Since you want to format it, let's blow away the partition:
1. Right-click [My Computer]
2. [Manage]
3. Disk Management]
4. Find your Maxtor in the list or graph.
5. Once you are certain, then right-click the Maxtor entry (or graph) and select "Delete Partition"
6. Answer [Yes] to the next scary question.
7. If it has other partitions, you may want to examine them and delete them later.
8. You can now "New Partition" (right-click)
9. The create a "Primary" drive and format it.
*done*
Sep 25, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Maxtor OneTouch III Mini not appearing on MacBook Pro
Hi Lois,
If your Maxtor appears in Disk Utility but the disk volume is not displayed, it's possible that the partition on the disk has been deleted for some reason. If that's the case, you will have to use a disk partitioning utility to create a new partition and then format the hard drive.
Best wishes,
Graemevm
Apr 28, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Need to format
Hi, You can try: 1. Open your "My Computer" and determine which of your HDs is the Maxtor III, say "E" or "F"; 2. Right click on the Maxtor III; 3. Click on "Format"; 4. On the File System, select FAT 32; 5. Click on "Start" Of course formatting your HD will delete its content. Alternately, you can: a. Open a command prompt window (type "cmd" in "Run"; b. type "format E: /fs:FAT32" assuming your PC assigned the drive letter "E" to the Maxtor III; c. hit "Enter" If for some reason this will not work, you may have to likewise delete the partition first. A handy 3rd party utility for the partition/format of a hard disk is Partition Magic. Hope this be of some help/idea. Post back how things turns out or should you need further information. Good luck and kind regards.
Oct 04, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Computers & Internet Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
