Question about Kenmore 62622 Microwave Oven
How to remove door switches on a kenmore 7216373300 microwave
How to replace the door switch?
If this isn't close to what you have, search on youotube - there are lots of microwave door switch videos!
Jan 08, 2015 | Kenmore Elite Microwave, Model...
Kenmore quick touck microwave, door latch hard to open & shut
If your want to start the easy path, get a Q-tip and some light weight grease and lightly grease the door-switch levers inside the door latch holes and see if that solves your problem. If not, then you will have to remove the cover, and likely you will find the door switch assembly and it's metal mounting support are bent on something of an angle - the switch assembly should be at 90 degrees to the front of the microwave oven so that he door latch fingers can slip in and activate the control switches easily all at the same time - straighten the switch frame which may require you to remove the switch bank temporarily. The little bit of grease still doesn't hurt to do it.
Reassemble.
May 11, 2014 | Microwave Ovens
Our Kenmore Microwave Hood combo model # 401.88529011 door sticks and is very hard to open off and on
Possible that the door lock is jammed, it can also be due to jamming of the door switch or the plastic lock being stuck on.
You need to remove the front panel , and reset the door assembly.
Jan 25, 2013 | Kenmore Microwave Ovens
How do I adjust the door switchs
Remove the grill on top and there will be a screw for the control panel. Once the control panel is tipped down you can see the door switches . Adjustment is a combination of the switch bracket and door hinge adjustment, You should have access to a Rf leak detector to inspect the door anytime the hinges or latches are serviced.
Eric
Jun 02, 2010 | Kenmore 62622 Microwave Oven
Kenmore microwave model number 72180019401 not heating food
check the door safety interlock switches inside. If you open the door while the oven is running, you have probably burned the little contacts inside the switch(s)
you must remove the cover to get to these switches.
need more help ... post here.
Thanks for using FixYa.com
Nov 02, 2009 | Microwave Ovens
Kenmor microwave 62344 runs but does not cook
Check the door safety interlock system. Remove the cover - test the little switches near the door lock.
These switches fail because we all open the oven door while the oven is operating. Thbis causing arcing and failure. When they fail, the oven doesn't know the door is closed and will not turn on the heat.
Need more help with this ...please ask.
Oct 19, 2009 | Kenmore 62342 Microwave Oven
Microwave door shut, but interior light is on - micro won't work
Yes. One of your door switches is not working. It could be an alignment issue or a faulty switch. There are actually 3 switches in the door latch area.
Eric
Sep 06, 2009 | Kenmore Microwave Ovens
Model # 721.80823500
f-5 code on kenmore microwave oven means a problem with the door lock switch. Could be a bent latch or latch assembly that’s not actuating the latch switch correctly or that the latch switch itself is bad. Check the door switch, too.
plse do not forget to accept the solution.
May 02, 2009 | Kenmore 63792 Microwave Oven
Microwave won't heat
The two possible causes are a faulty door switch and a bad magnatron. You can pull the top cover off of the unit and check all of the door switches (there are 2-6 of them all on a common rail, me normally closed)). If the door switches all check out, replace the magnatron, diodesmag-glass_10x10.gif, and capacitor
Oct 28, 2008 | Kenmore 62622 Microwave Oven
No power
The door switches are designed to prevent the unit from running while the door is open. You probably have a blown fuse, and it's a white or dark grey ceramic fuse of 15A or 20A, available from local big box stores or appliance parts stores. The fuse is usually located on the floor of the chassis behind the control panel, or mounted in the same area as the door switches. Also, I'm really curious how the door switch got stuck while cleaning? That sounds scary...
Nov 13, 2006 | Kenmore 62622 Microwave Oven
Kenmore 62622 Microwave Oven Logo
18 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
