Question about Sony VAIO T140P/L (VGNT140P) PC Notebook
Looking for screen and keyboard
Looking the best place to purchase screen and Keyboard to my Sony Vaio VGN-T140P.
    President:
  • Sony Master
  • 1,314 Answers
EBay is the best place for this type of thing. It's way cheaper than any laptop depot I've come across. Here's one for your keyboard: http://cgi.ebay.com/Sony-Vaio-Laptop-Keyboard-VGN-T140P-HMB991-D01-NR_W0QQitemZ320137022753QQihZ011QQcategoryZ140084QQssPageNameZWDVWQQrdZ1QQcmdZViewItem As far as the screen is concerned; the way to get the best deal is to search by model number of the screen and not just laptop. The same screen can be used in several different laptops. Take your screen out and look on the back of it. There will be a model number there. Enter that model number into ebay's search, making sure you check product description to be included in the search query. Any screen matching that model number will fit your laptop just perfectly and it will save you a bundle.
Posted on Jul 16, 2007
SOURCE:
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
I have a sony vaio vgn fs980 laptop. all of a sudden the keyboard stop working. i purchased a new keyboard. However the same problem exists. I can use an external keyboard that will work fine but the...
On every computer motherboard there is what's called a UART chip. This chip is responsible for capturing every keyboard click, interpreting what letter it is, converting it to zeros or ones used by computers, and sending it to the processor for action. If this chip fails, even replacing the keyboard won't fix it.
Unfortunately this chip is usually part of the motherboard so the only way to replace it is to replace the motherboard, which usually isn't cheap. If you can live with the external keyboard you might want to stay with that. Otherwise, if you Google sony Vaio motherboards, I'm sure you can find a number of sources online to purchase a motherboard. Replacing one is tricky but not insurmountable if you take your time and can follow directions, also available online.
Best of luck! Hope this helps!
Jun 21, 2011 | Sony VAIO VGN-FS980 Notebook
VAIO VGN-C25G/B needs new buttons for the letter
The best way to solve your problem is to replace the keyboard.
Keyboard replacement are available on the Internet, I got one from this site :-
http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Sep 28, 2009 | Sony Computers & Internet
Messed up keyboard
Your best bet for cheap, decent keyboard will be eBay!!
Have a look at some of these>>>>
http://shop.ebay.com/?_from=R40&_trksid=p4738.m38.l1311&_nkw=wireless+keyboard&_sacat=See-All-Categories
If you do decide to go with eBay for a new keyboard make sure you purchase one from a "Power Seller" and read their feedback too.
Good luck.
Aug 28, 2009 | Sony VAIO VGN-A190 PC Notebook
I purchased Vaio VGN-ns21m keyboard dont function f1 f2... canc
i guess f1, f2, and all the function keys are given with added fn key in the left corner of the keypad. search for the blue icon with fn in the keypad. that should solve it. press fn along with the key you want to use.
Aug 12, 2009 | Sony VAIO VGN-N320E Notebook
Keyboard sony vaio problem
Try using the character map in Windows XP.
You can find it by selecting Programs » Accessories » System Tools » Character Map.
It will look like this:
Best of luck,
Steven
Aug 31, 2008 | Sony VAIO VGN-N130G/W Notebook
Open Questions:
\Q;- KYOCERA PRINTER customer support phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This KYOCERA PRINTER USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 KYOCERA PRINTER USA customer tried our tools and information and gave us feedback after they called. The reason customer call [+I8OO-8O3-1069] is to reach the KYOCERA PRINTER USA techanical support department for problems like Where to buy, Complaint, techanical support, Repairs, Returns. As far as we can tell, KYOCERA PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KYOCERA PRINTER USA has 2 phone numbers and 4 different ways to get techanical help. We've compiled information about I8OO8O31O69 and ways to call or contact KYOCERA PRINTER USA with help from techanicals like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KYOCERA PRINTER USA Calling KYOCERA PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KYOCERA PRINTER USA techanical support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KYOCERA PRINTER USA's techanical support department, you may need to provide them with information that identifies you as a techanical, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KYOCERA PRINTER USA's phone numbers against each other. Contacting KYOCERA PRINTER USA in General While [+I8OO-8O3-1O69] is KYOCERA PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their techanical support team. You already know from reading above that[+ I8OO-8O3-1O69] is their best techanical phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach KYOCERA PRINTER USA help by calling them, is that other techanicals give their techanical support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KYOCERA PRINTER USA.
Oct 18, 2019 | Kyocera Computers & Internet
\Q;- RICOH PRINTER customer support phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This RICOH PRINTER USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 RICOH PRINTER USA customer tried our tools and information and gave us feedback after they called. The reason customer call [+I8OO-8O3-1069] is to reach the RICOH PRINTER USA techanical support department for problems like Where to buy, Complaint, techanical support, Repairs, Returns. As far as we can tell, RICOH PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. RICOH PRINTER USA has 2 phone numbers and 4 different ways to get techanical help. We've compiled information about I8OO8O31O69 and ways to call or contact RICOH PRINTER USA with help from techanicals like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling RICOH PRINTER USA Calling RICOH PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from RICOH PRINTER USA techanical support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with RICOH PRINTER USA's techanical support department, you may need to provide them with information that identifies you as a techanical, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare RICOH PRINTER USA's phone numbers against each other. Contacting RICOH PRINTER USA in General While [+I8OO-8O3-1O69] is RICOH PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their techanical support team. You already know from reading above that[+ I8OO-8O3-1O69] is their best techanical phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach RICOH PRINTER USA help by calling them, is that other techanicals give their techanical support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact RICOH PRINTER USA.
Oct 18, 2019 | Ricoh Computers & Internet
\Q;- KODAK PRINTER customer support phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This KODAK PRINTER USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 KODAK PRINTER USA customer tried our tools and information and gave us feedback after they called. The reason customer call [+I8OO-8O3-1069] is to reach the KODAK PRINTER USA techanical support department for problems like Where to buy, Complaint, techanical support, Repairs, Returns. As far as we can tell, KODAK PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KODAK PRINTER USA has 2 phone numbers and 4 different ways to get techanical help. We've compiled information about I8OO8O31O69 and ways to call or contact KODAK PRINTER USA with help from techanicals like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KODAK PRINTER USA Calling KODAK PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KODAK PRINTER USA techanical support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KODAK PRINTER USA's techanical support department, you may need to provide them with information that identifies you as a techanical, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KODAK PRINTER USA's phone numbers against each other. Contacting KODAK PRINTER USA in General While [+I8OO-8O3-1O69] is KODAK PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their techanical support team. You already know from reading above that[+ I8OO-8O3-1O69] is their best techanical phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach KODAK PRINTER USA help by calling them, is that other techanicals give their techanical support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KODAK PRINTER USA.
Oct 18, 2019 | Kodak Computers & Internet
See all Sony VAIO T140P/L (VGNT140P) PC Notebook Questions
Sony VAIO T140P/L (VGNT140P) PC Notebook Logo
176 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
