Question about SanDisk Sansa e250 MP3 Player
Wheel of my sansa is so sensitive
The wheel of my sansa is so sensitive when i scroll it..,how do i repair this??
    Problem Solver:
  • 13 Answers
Hi There,
You need to do the following. I did it to mine yesterday and it's great!
http://joustin.com/?page_id=10
Posted on Jan 27, 2009
  • oposomx Sep 19, 2011
    I encountered the same issue. Tried the link above, but it brings you to an empty page.
    Do you have any idea how to fix the problem with the scroll wheel??
I just purchased a mp3 and somehow got it in the spanish mode.. how do I get it back to english
1) Turn on your Fuze, and press the Home button (little button to upper-right of scroll wheel).
2) Scroll to the "Parametros" (Settings) menu, and click the scroll wheel to enter it.
3) On the Pamametros menu, scroll down to the last item, which should be "Configuracion del sistema" (System Settings), and click the scroll wheel to enter it.
4) On the Configuracion del sistema menu, scroll down to the 6th item, which should be "Idioma" (Language), and click the scroll wheel to enter it.
5) On the Idioma menu, select the top item "English".
Feb 17, 2010 | SanDisk Sansa Fuze MP3 Player
I left my Sansa Clip MP3 Player plugged in while putting my laptop into hibernation. Now player does not response, I can't turn it on, and laptop doesn't recognize it at all.
    Complete Reset of Sansa Clip
  1. Step 1 Turn Sansa Clip on. Press the "Menu" (Home) button on the Sansa Clip.
  2. Step 2 Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
  3. Step 3 Scroll down to "Reset All," and select. You will be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow steps 4 and 5.
  4. Step 4 In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm if you wish to format. Select "Yes."
  5. Step 5 Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
  6. Resetting a Frozen Sansa Clip
  7. Step 1 Unfreeze a frozen Sansa Clip by pushing the power button up and holding it for 20 seconds. Release it, and then turn it on again.
  8. Step 2 Go to the Sansa website and download the "Sansa Firmware Updater."
  9. Step 3 Select "Run" when the updater installs. (Installation will take less than two minutes.)
  10. Step 4 Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
  11. Step 5 Connect the Sansa Clip and then remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Aug 22, 2009 | SanDisk Sansa Clip MP3 Player
How do you record FM radio on Sansa Fuze?
OK, while in radio mode, press the bottom of the wheel, scroll down to 'Recording', then select 'Record Now'.
(I have a Sansa Fuse too, so, i know my way around it.).
this should help.
Jul 22, 2009 | Audio Players & Recorders
Ball wont scroll downwards. Ball will only scroll from side to side. Cant access any of my applications.
Cause:
The sensitivity of the trackball/trackwheel might be less
Faulty Hardware
Resolution:
Increase the sensitivity by following procedure
Option -> Screen and Keyboard -> Horizontal Sensitivity and Vertical Sensitivity to 100
if still not working contact service center
Jul 08, 2009 | RIM Blackberry Curve 8300
New Sansa View Scroll wheel won't work
If it's brand new and you bought it at a store, exchange it. If it's an online store and not refurbished you should probably call Sansa as it will be in warranty. If it's refurbished (has a silver capital R sticker on the back) or was an auction item then you can either call Sansa (although they aren't much help with refurbs). If you aren't afraid of working with small objects, are reasonably intelligent, and own a screwdriver, then you may want to clean the contacts (I don't know if this will void an existing warranty or not). Instructions are at: http://joustin.com/?page_id=10 Note, he uses rubbing alcohol but a less messy method is to use the eraser from a standard #2 pencil (pink eraser) to do the cleaning. (Alternately you can use any contact cleaner spray made before 1990 without opening the Sansa...of course the good stuff was banned for manufacture so newer stuff may not work)
May 10, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Scroll wheel
Well, you probably have a fast scroll wheel. If you aren't doing it already, try installing Rockbox from rockbox.org This will give you some more control over the speed, and I personally use it. If you do not want to void your warranty, try updating to the latest firmware.
Feb 03, 2009 | SanDisk Sansa E280 MP3 Player
Scrolling mouse - it creeps 3 or 4 lines after the scroll wheel is stopped
Such a problem generally comes when your scroll sensitivity is high, try reducing the scroll sensitivity from
control panel -> mouse
if you mouse scroll does not take quantized steps (moves continuously rather than in steps ) this is quite a common problem and can also be reduced if not completely removed by decreasing scroll sensitivity.
Aug 26, 2008 | Computers & Internet
BLUE SCROLL WHEEL STICKING.
May have been exposed to too much heat. sorry.
Dec 06, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
243 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
