Question about Motorola Mobility RAZR V3
Parrot V 5.25d to pair motorola WX308 - Motorola Mobility RAZR V3
Cannot pair blackberry 8520 with parrot ck3100
I could not pair the Blackberry Curve 8520 with the Parrot CK3100. After looking at the Parrot website, I saw that the Blackberry was actually supported, so it SHOULD work.
Then I found the solution: the Parrot had already too many other phones paired (4 or so), so it could not pair an additional one. After removing the other phones from the Parrot pairing list, the Blackberry paired without a problem. SOLVED!
Davy
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
Parrot CK3100 and connectinity issues with Nokia E73 phone
Have you contacted the manufac of the Parrot? Just a little heads up. dont bother calling your cell phone povider..they will only troubleshoot there own devices...Ive got that run around about my bluetooth I ended up calling Motorola and problem was resolved
Apr 19, 2010 | Nokia E72 Smartphone
Cant pair parrot to nokia 5800 was paired but accidently deleted all devices. I only need the 5800 paired. no paired devices is displayed on screen. have kept bluetooth on phone displays the parrot wont...
you will have to pair them together again, search for devices from your phone and select parrot, then enter pin code 1234 when prompted, this should then pair again.
Nov 14, 2009 | Parrot MINIKIT Bluetooth Hands-Free Kit...
It doesn't let me punch in the code of 0000. other phones are easier to pair.
Go to settings/ pair with phone/ other phones. it will then give you the code to use, then search for new paired device from your phone, when it finds parrot, click pair and enter code shown on parrot screen. Make sure you delete all other paired devices from parrot first. instructions can be found at parrot.com
Oct 30, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Pairing a Parrot CK3100 to Iphone 3GS
My iPhone 3G is now connected. Did 3 things:
1. Deleted every existing paired device on the Parrot CK3100.
2. Pressed all 3 buttons at once. Parrot CK3100 screen lit up and buttons lit up after about 5 secs. Turned car engine off. Parrot switched off. Turned car on again.
3. Went to settings, advanced settings, pair device (and also switched on iPhone bluetooth) and tapped Parrot CK3100 on the iPhone screen (which had now appeared) - phone connected.
After about a minute sync iPhone phonebook appeared on Parrot.
Hope this is helpful.
Jun 27, 2009 | Apple Cell Phones
Pairing with lg phone
The display should read "Goodbye" when turning the car off. Try switching the inline fuse holders. (Orange and Red Wires)
Jan 09, 2009 | Parrot CK3300 GPS Receiver
New phone needs to be connected to my Parrot
You will need to go to settings and paired devices, delete any old devices, then go to settings / advanced settings / pair with phone. this will then give you a pin code to enter. Now search from your phone for Bluetooth devices, select parrot and enter the code given.
you can find a manual at parrot.com
Dec 22, 2008 | Parrot Ck3400ls Bluetooth Lcd Car Kit With...
I can't connect Verizon Gleam SCH-U700 to Parrot CK3100
This solution came from Parrot Tech Support and it worked for me:
We were able to get the two to pair using the following steps:
The phone will stay saying pairing, then the parrot will say pairing successful, pull the battery on the phone, when you turn it back on, the phone will display PARROT CK3100 WANTS TO PAIR, ACCEPT? Say YES.
Mar 11, 2008 | Cell Phones
Motorola Mobility RAZR V3 Logo
146 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
