Question about GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo...
Broan compactor. The compactor ram is stuck partially down and we can't open the drawer. How do we get the ram to go back up so we can open the door?
2 Suggested Answers
SOURCE: Compactor ram stuck partially down & door open
We just had this same problem. Your problem is most likely abroken plastic gear found at underneeath the bottom of the compactor. Pull out the compactor and turn it upside down. Remove the bottom panel and that is where we found the broken gear. We were able to retract the ram and open the drawer by manually turning the drive chain using an ajustable wrench. Clockwise is compact, counter clockwise is retract.
Posted on Feb 21, 2010
Why won't the ram come back up on my GE compactall ?
yes you may but there is a limit switch that stops the ram when it is at the top sometimes the piece that goes with the switch will get bent and cause a problem like you are having,
Apr 25, 2014 | Kitchen Appliances - Others
Tip
Trash Compactor Problems Why it Does Not Work
Trash compactors can be a very nice feature and addition to your kitchen. However they can also be very hard to work on if they go bad. There are 20 some brands of trash compactors available, but the KitchenAid trash compactor is one of the most common.
If your trash compactor does not work at all here are some things that you will need to check.
First off make sure that you are getting power to the unit. Many are plug into by code a GFCI wall socket. These outlets do a great job of protecting against shock, but do a terrible job of staying on, especially when used on a motor that pulls a high amount of current when starting. It is not uncommon for them to go bad and trip for no reason at all after a few years. If the outlet is tripped, try to reset it by pushing in hard on the reset button in the center of the outlet.
If you have power at the outlet, then you will need to check through the circuit in the compactor. This can include a door switch, micro switches that sense the position of the ram, and possibly a key switch. Make sure that there is nothing stuck behind the drawer that would keep it from going fully shut. Check the position of the ram to see if it has returned all the way up.
If your ram is stuck down or if it will not go down, check for broken drive gears, belt, of chain. Make sure also that the switches that sense the ram position have not move and come out of place.
Your trash compactor will also need to be clean periodically. Food spilling on the tracks or glides can cause the drawer to slide hard or even become stuck. Clean all the slides or glides, wheels tracks and such with warm damp cloth and the re oil everything with a household lubricant. With time and use the wheels and bearings may also need to be replaced to keep your trash compactor operating well.
on Feb 28, 2010 | Kitchen Appliances - Others
I've got a GE trash compactor (GCG1580PSS). The door is stuck, presumably because the ram is stuck in the down position. If power is turned on, it will run until it shuts down (faint smell of...
Look up and down, may have an installation apparatus hooked into the counter top and the floor. Go to manualsonline.com to download owner's manual which should have installation information in it. Hope that helps..
Jul 19, 2011 | GE Profile GCG1580LSS 15" Built-In Trash...
Kitchenaid trash compactor bought in 2000; no model/serial number found. Compactor was stuck in partial down position; worked the drawer out and found cotton fibers wadded/stuck at top of the up/down...
at the top, above the ram, there are two switches. One is the reversing switch (should have 4 wires), the other is the stop switch (2 wires). I suspect that the switch arm is bent, due to what you just described, and fails to activate the switch to stop the motor when the ram is at the top position.
May 24, 2011 | KitchenAid Microwave Ovens
Compactor will not close and latch. I removed the trash bag and installed a new one then closed the drawer like normal, only drawer would not stayed closed. It just bounces back out.
you will need to remove the entire Drawer to see if somthing fell behind inside.
Most of the time you can pull the drawer all the way out and lift the front of the drawer and pull it out.
Feb 21, 2010 | KitchenAid P Series Trash Compactor -...
Compactor ram stuck partially down & door open 2 inches. How do I get the ram to go back up & get the door closed?
Feb 03, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Have a Viking trash compactor VUC181 that will not open. Appears latch is broke. How can I get it open?
I have had this same problem and found two causes. Latch was never the problem.
#1 - Ram not in full up position. To check remove top plate and attempt to run compactor - depressing microswitch when ram is at the top. If compactor will not run you can check the ram position by turning the primary screw drive with a ratchet wrench. When ram is at the top position attempt to open the compactor drawer. The stop microswitch seems to frequently bend out of alignment - check the microswitch positioning before resecuring top plate and adjust if necessary.
#2 - Can (or other debris) is wedged in between ram and drawer. Remove back cover and carefully inspect insides of the unit - use a flashlight. Pry out any debris that may impede the drawer from opening. Attempt to open the compactor drawer.
Good luck,
Jon B.
jbroccoli@aol.com
Oct 10, 2008 | Viking 24 in. Professional Series VUD141...
Stuck Trash Compactor
I can't get to the rear of the compactor. How do I get the front off to get to the rest of it?
Mar 14, 2008 | Dishwashers
Trash compactor problem
I have had this problem on my GE Monogram. The 'smasher' is near the bottom and does not move anymore, even though the motor is working.
What I did was to get a crowbar that would fit through the crack and hook the underneath side of the bottom plate. You also have to hold the switch so the motor runs with the door open and pull up on the plate until the drawer can be slide out. The trunnion nut (a plastic nut) was cracked. I replaced it 3 years ago, and it just cracked again. They now make it out of metal, so maybe it will last longer. Ordered it from appliancepartspros.com.
Jan 11, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo... Logo
54 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Sal DeAngelo
christian nielsen
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
