Question about ASUS F3Jm Notebook
GPU replacement I was investigating upgrading my laptop, mainly getting a new cpu and gpu. I know where the cpu is, but am having problems finding the graphics card. any help would be greatly appreciated thanks.
GPU cooling problem
Try reinstalling the heat sink and putty on GPU. Make sure heat sink is fitting correctly. If the only thing you did was upgrade the fans and redo the putty, then your heat sink didn't seat properly.
Nov 01, 2013 | Acer Extensa Computers & Internet
Toshiba Satellite L505D-S5983 Sorry if this is choppy but I kept getting use only legal characters and I can't seem to figure out what it is referring to I looked into the reflow process but when I...
The GPU in every laptop is soldered in place, if you have a lot of experience with reflowing then you can try to pull the GPU and replace it but a lot of the time it's actually more cost effective to get a replacement MB and sell the one that's having issues. Because the GPU may not be the only part that has gone out or it maybe another part that has gone out and is keeping the GPU from powering or outputting signals
Oct 29, 2013 | Toshiba Satellite L505D-S5983,...
How to replace the graphics card in my samsung np sf510 laptop
Replacing the graphics processing unit is a tricky business which involves disassembling and reassembing the virtually the whole unit.
I would reccomend a professional do the upgrade unless you are familar with notebook assembly.
Firstly make sure that the graphics card can be upgraded in the first place as they some-times form part of the computer's mainboard. Consult google in this regard.
Disassemble the unit to expose the CPU, Mainboard and Graphic Card. Usually these componets share a cooling assembly. You will need to carefully remove this.
Now remove the screw/clip that secures the GPU to the mainboard, then remove the card from the mainboard. Now pop your new one in and reinstall the cooling assembly applying new thermal interface material to CPU, Mainboard and GPU.
Reassemble the unit.
Take care!
damnor01
Sep 12, 2012 | Samsung Computers & Internet
Upgrade HP Compaq Presario F750US - CPU, GPU & RAM
You'll spend more money trying to upgrade this laptop then it would cost to just buy a better used one on eBay. Probably even spend more that it would cost to buy a new low end computer. Save yourself the headaches and time and buy a NEW laptop.
Jun 13, 2012 | HP Compaq Presario F750US
My dv6000 will power up and go back off
This model of laptop has an overheating problem. This problem affect the Nvidia GPU and cause that issue. You have two options, one cheap and one expensive.
The cheap one is that you must overheat the Nvidia GPU, in order to resolde it again. This procedure you can make it with a Heat Gun. I mean you need to extract the motherboard and apply the heat directly to the GPU 90 seconds max. Put all the pieces together again (dont forget to apply thermal paste to CPU and GPU) and when the laptop turn on again, go to the HP website and download the las Bios update to your model.
This solution give you as long time as you work with your laptop fresh. You can download the CORETEMP application, to keep watching the CPU temperture.
Cost: $ 20 Heat Gun (harbor freight), $ 7 new thermal paste (for the CPU and GPU)
The expensive one is send your computer to a authorize service center and ask for a reballing repair to your GPU. Cost may be $ 200.
If you need more details, let me know. GOOD LUCK
Feb 16, 2011 | HP Pavilion dv6000 Motherboard
I have an HP laptop with a quanta 30BC motherboard. What is the fastest cpu I could put in this? Also, could I upgrade the GO 7400 GPU?
hehe, you cant swap gpu chips on laptops but I can
but I have super infra red equipments and 10 years of experience in bga reworks.
from the picture there is space for go 7400 in the empty bga 0.6mm type to go there but can you find someone to do it?
www.laptopreballing.co.uk
Jun 04, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Laptop freezing acer aspire 5520
If you are carrying it around, and you are getting black lines across the screen, you have a lot more than thermal pads to be concerned with. The connections inside are breaking down and arcing. (That's what the ssszzzzzzzZZZTTT noise is).. Unless you are good at repairing printed circuit boards, you should take it to a repair shop.
Sep 17, 2009 | CMB T43 750 Notebook
Upgrading cpu and gpu on toshiba portege m400 -s933 laptop
Next time you get nasty with me on answers, I'm gonna nuke your pc so bad you wont NEED a new processor! Surface mount technology has NOT been around for 50 years to the general public. You are a friggin moron who thinks they know something! I've been involved for 30 plus years in the field PUTZ!
May 20, 2009 | Lenovo 3000 Y410 Laptop
Monitor shuts off of the computer then stays on then goes off .
Does it shut off with absolutely no warning sounds whatsoever?
Do you ever hear a faint PC beeper alarm that kinda sounds like a ambulance siren (you know... kinda like a WEEEE. ORRRRR... WEEEE... ORRRR)
My main suspect at this stage is OVERTEMP (you are overheating the CPU).
Possible Causes: Recently UPGRADED components (especially VIDEO)
Build up of dust in Case and CPU heatsink and GPU heatsink or CPU fan has failed or one or some case fans have failed.
Do you know how to check your CPU temp in BIOS? If it happens again check it out.... greater than 90 degrees is usually bad.
Check all your fans are spinning, check you don't have 'caked up' dust on your heatsinks.
If you have recently upgraded a major component that is dumping heat into you case... investigate a new case fan to extract this heat (cheapest option) or you may want to pick up an aftermarket CPU heatsink and fan (Thermalright FTW!!!!!!!)
Mar 22, 2009 | Computers & Internet
ASUS F3Jm Notebook Logo
115 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
