Question about Brother DCP-350C InkJet Printer
Our Printer Brother DCP 350 C paper Jam Problem
It is a paper jam problem instantly
  • Anonymous Mar 12, 2009
    My DCP 350, two months old has the same problem, could it be the paper I am using is to heavy 255g/m2 ?. I have been using this same paper for about 5 years with previous Epson and Canon models never a problem. Can I adjust it to accept..
SOURCE: Paper Jam in Brother DCP-135C - cannot even see the stuck bit!
lift the top lid and ge it out from the top
Posted on Feb 17, 2009
SOURCE: Paper jam in Brother HL-2140 printer
I have the same problem - try what it says at this link.
Posted on Mar 18, 2009
SOURCE: Paper Jam lite is on ( no paper jam )
did you try turning it off and then back on?
Posted on May 27, 2009
SOURCE: not printing glossy A4 paper / paper jam / no paper feed
dont use thick photo paper like 230 gsm up, instead use 180 gsm papers. but if you dont want to waste the purchased thick photo papers, you can open the back and manually insert the paper once the printing process started. i tried this as a trial & error basis until i had perfected it.... hope it works with yours.
Posted on Aug 17, 2009
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean paper jam occured
Clean 50 is either Dirty Encoder Stripe or broken Maintenance Unit. In first case clean thoroughly the vertical Encoder Stripe and it should work. In case 2 better exchange the machine
Nov 23, 2015 | Brother Office Equipment & Supplies
Printer paper jam
Go To Below official Brother Printer Page For Your problem, How do clear paper jams Brother Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
Mar 24, 2014 | Brother DCP 130C All-In-One InkJet Printer
kindly check your encoder strip if their any dirt just clean it.... you need to disassembly your machine 1st... and after that if the problem still exist you need to clean the sensor or your printer head....
Sep 06, 2011 | Brother DCP 165C Compact Color Inkjet...
Error 50 of Brother printer DCP-130C
Details of this error code are.
5D,5E The machine does not work due to a paper jam or some sensor problem. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us".
May 01, 2011 | Brother DCP 130C All-In-One InkJet Printer
How to remove a paper jam brother printer
You may encounter a paper jam while working with your Brother printer. You need to be cautious while feeding the paper to your printer. Paper jams are often obvious, but you might come across a situation when you do not get any indication that the paper has jammed up the printer. In such cases, you need to open your printer and visually inspect it to search for the jammed paper. If the rollers of your printer are leaving marks on the printouts, then there is a need to clean them. Using chemical cleaners such as benzine, thinner, or alcohol to clean the rollers might prove hazardous to your printer.
Get more information and help for Brother Carriage Jam .
Nov 29, 2010 | Brother DCP-9040CN Laser Printer
I have a brother DCP-135C with a printer jam. I followed the instructions in the user guide and believe I have removed all the paper but still get the paper jam message. When I unplug then plug it back in...
for this model, normally the paper is stuck behind., you can open the rear part of the printer and check if there is any paper stuck there.
lift up the scanner unit and switch on the printer, does the sound come from the print head side, it could be due to the print head getting stuck... the encoder belt might be damaged...
May 20, 2010 | Office Equipment & Supplies
1. Paper Jam 2. No black color
for Paper Jam when using photopaper please check below
Jul 08, 2009 | Brother DCP 165C Compact Color Inkjet...
Brother DCP-350C InkJet Printer Logo
91 people viewed this question
James Cagle
James Cagle
Jim Keysor
