Question about Brookstone Flash Sport Band Watch
How do you turn on and set the brookstone flash band watch
Turn off military time
This baffled me for a bit...Finally I just took the batteries out, then put them right back in and it was no longer on military time.
Apr 06, 2013 | Brookstone LEGO Ninjago Kai Mini-figure...
How do you set the time/date, etc.? This watch is a 1440 sports with plastic wrist band.
press and hold mode button until the digits flash (it is to set the alarm) then press again once the mode button, this time the time flash to be set, the digit that flash is changeable, the lower right button is for adjusting, the upper right button is to choose what you are going to change, while pressing the upper right button you will see all you have to change the time , the date, the day of the week. if your done with all of this. press mode button once, i hope i had been helped you.
Sep 06, 2011 | Timex 1440 Nylon watch
How do I set time on the Brookstone Ipod cube radio? Thank you
Simply HOLD down the "CLOCK SET" button for ~3 secs and the time will flash... Rotate the dial around the SNOOZE button to the hour you want; click the "CLOCK SET" button again for the minutes and rotate the dial again... Hit the "CLOCK SET" button one last time and you're done! Need help with solving real problems? Contact me at Help@OPRIMAX.com
Jul 23, 2011 | Brookstone (467522) Clock Radio
Brookstone SLCDv2.0 The device clearly has a Memory capability since there is a "Set" button and the display shows "Memory" when the button is pressed at a particular FM station. ...
Hi, The receiver does have an in built memory to store upto 6 channels.Please follow the steps below to set up the radio memory:- Up to six favorite radio stations (3 AM and 3 FM) may be stored in memory. the following are steps to set radio memory: 1. Press tUnInG/bAnD to select the band. 2. turn tUnInG/bAnD to locate the desired station. 3. Press the M button. the "M" indicator flashes on the LCD Display. 4. Press 1, 2 or 3 to store the selected station. 5. Press the M button again to confirm. 6. repeat steps 1-5 to set other memory stations.
Incase you would require any information do refer the below web site where you could find picture representation of the same. http://www.brookstone.com/linkedassetservlet?assetId=71937&languageId=EN
Thank you for your time and best wishes for your effort.
Jan 11, 2011 | Audio Players & Recorders
White band turned yellow
mcdevito75 here, Sounds like the chlorine in the pool water dis-colored the band, not to mention, possibley the watches mechanism also. Look for a small watch repair shop in your area for a new band and possible remedy for the water inside the watch.
Jul 07, 2010 | Adidas Adibot ADH1325 Watch for Women
How do you set the time on Brookstone iDesign Cube Clock Radio?
Jul 05, 2010 | Brookstone (467522) Clock Radio
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Feb 18, 2010 | Clarion Car Audio & Video
I need to set time on my breo roam watch
On the inside of the wrist band there are two small silver buttons. Press the top one using a straightend out paper clip until the hour flashes, then use the bottom button to change the hour. Press the top one again to get the minute to flash and the bottom one to change the minute. Then press the top one again.
Feb 01, 2010 | Watches
I want to know how to turn on the hourly chime on timex ironman 30 lap watch
I have a Timex Men's Classic Digital Silver-Tone Expansion Band Watch #T78587. To turn the chime on and off on this watch, I press the Start/Stop button on the top right once. This toggles the chime on and off. If you hear a single beep then you have turned it on. If you hear no beep you have turned it off. You can tell the chime setting by looking at the colon seperator between the hours and minutes. If it is flashing then the chime is on and if it is not flashing then the chime is off. This is not explained in my watch manual nor in any of the manuals I downloaded from Timex.com.
Dec 14, 2008 | Timex Ironman 30 Lap 53952 Wrist Watch
Brookstone Flash Sport Band Watch Logo
41 people viewed this question
Top Brookstone Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Brookstone Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
