Question about Coffee Makers & Espresso Machines
Krups ea8010 fault code 9 - Coffee Makers & Espresso Machines
2 Suggested Answers
  • 5 Answers
SOURCE: Error Code 9 on a Krups XP7240 Expresso machine
After I changed piston sealing I get the same error 09. It was caused by missing connection to the thermoblock temperature sensor. In my case both connectors for thermocouple were cracked. They are located directly on the body of thermoblock, below two fuses, covered by rubber housing. After I solder them again on the position error 09 disappeared. Unfortunately it is necessary to open at least front panel of the machine. Moreover I tink that there is also important to save polarity of those two cables.
Posted on Aug 07, 2009
What is error code 6 on krups ea850b10 means?
Error 6 means machine thinks it has a leak in one or more of the following
1) Distributor
2) Thermoblock
3) Pump valve
4) Pipe leakage
Repair will involve specialised tools and parts, not really the sort of job to attempt yourself. Contact Krups and get from them contact information for your local service agent.
Aug 03, 2015 | Krups Small Appliances Espresso Machine
Krups ea8010 expresso machine The CALC light comes on when switching on the machine . Then after 1 min it's starts spraying water from the frother . And keep doing that every 1 min. What should I do ?
It seems like it is part way through the descale process, put 500ml of water in the tank and let it run. Once tank is empty after a couple of minutes it may detect nil water and request next part of the process. If not then brain may be scrambled which may involve a trip to authorised service agent.
Mar 17, 2015 | Krups Coffee Makers & Espresso Machines
Hej Ross ,u seem to be quite the expert on krups expresso machines.I have a 8010 model that was leaking.I changed the rubber seals but now it makes that start up check and it keeps saying there's a fault...
It has to be one of the micro switches either not being activated by whatever touches the switch button to switch it or the switch itself is not making or breaking the circuit. You will need to carefully check your assembly, there is the possibility to not get things exactly as they need to be or maybe something has been bent or damaged during the repair process. There is no chance to delete or bypass the switch, the pcb will always be looking for a pulse from the switch so removal is not an option. If you put jump wires to a multi meter one switch at a time and then run the machine you should be able to first find the switch that is not pulsing and then once you are looking in the right place figure out why that is so. EA8010 is not a model we have in my country but we have had earlier versions which must be very similar.For me this sort of testing is very easy because I have extra outer housings with huge cutouts so I can operate and inspect at the same time. For you it is not going to be so easy.
Jan 25, 2015 | Krups Coffee Makers & Espresso Machines
How do i open krupp ea8010
manualspoint.com/results.php?search=krups+ea8010+service+service
Jan 17, 2015 | Washing Machines
Krups ea 8010
Error code 9 is temperature detected as too high or too low. Check NTC on boiler
NTC fault (component, bonding, connector, wires...)
Coffee leakage on NTC (resistor value)
Jan 15, 2014 | Krups Coffee Makers & Espresso Machines
Error code 3 on krup xp7220
Direct from repair manual for your model, these are the possibilities
- Fault in the actuator high
position switch (mechanical or
electrical)
- Distributor switch fault
- Faulty electronic boards
connection
- Actuator switch short-circuited
Dec 08, 2013 | Krups XP Coffee Makers & Espresso Machines
How to open repair Krups EA8010
have problems with the mill hack, how can I repair it
Jul 15, 2012 | Krups Coffee Makers & Espresso Machines
Need instruction manual for a krups juicer
I do not have a manual or the tool that takes it apart.
Sep 20, 2009 | Krups Juicers
Jun 06, 2009 | Krups XP4030 Espresso Machine
Coffee Makers & Espresso Machines Logo
52 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
