Question about HEWLETT-PACKARD G62-347NR Laptop
Touch gesters Mouse only moves horizontal
How to perform scroll function in laptop without mouse in Dell vostro
Your touch pad should do the trick.
They are called "Gestures". They are set to active by default. If it's not. Go to "Control panel > click "mouse" and find "touch pad". There you will find "Gestures". Activate it.
1. Put two fingers on the touch pad and try to move both fingers up or down. Learn how to scroll up and down.
2. Move those fingers side ways. This should do the "Horizontal" scroll.
There are others, like:
Put one finger stationary and rotate the other. This rotates the orientation of the object.
Try it and good luck.
May 23, 2014 | Dell Vostro 1510 Laptop
My touch pad works with a mouse,but when I tap my touch pad nothing happen's,thats when I lef click my mouse,it will move the icon,but wont tap on toanything
This has happened to me and it took me hours to figure it out. I hope yours is the same problem...
Make sure you dont have your touch pad set to off. On my ASUS It is F9 on my keyboard. the key shows an icon of the touch pad with a slash (/) through it. If you do not see this on your keyboard try looking in control panel and see if there is a setting in there. Good Luck. Please let me know if this worked.
Geraldine
Nov 18, 2011 | Computers & Internet
Curser will not move
Hi and welcome to FixYa!
If you are using the touch pad and the cursor will not move, you may want to try and use a mouse. The touch pad on your computer may have worn out. If the mouse works, it may be your pad.
Please check to make sure that touch pad button is on. If the mouse will not move the cursor, your drivers may have been corrupted and you have to download new drivers after uninstalling the old one. Which one you download will depend on what type of computer you have.
Thank you for asking FixYa!
KittyTech
Nov 14, 2010 | Computers & Internet
While I type, often the cursor moves to the poit where the mouse icon is locatde, as if the touchpad has been pressed.
yeah you have touch sensitivity set to high in the touch pad and your wrist is hitting the touch pad. go your touch pad settings in the control panel and turn it down til when your wrist brushes it, it doesn't move the mouse.
Mar 23, 2010 | Dell F3534 Touchpad
Mouse wont move
Are you referring to the mouse pointer when using the touch pad? To isolate the problem, try to use a USB mouse and see if the pointer will move. If the USB mouse works, then the touch pad could be disabled.
Refer to the user manual of the laptop and see on how you can enable the touch pad.
If same problem occur even though you're using a USB mouse, contact the manufacturer of the computer for second opinion or repair.
Good luck and have a great day!
Feb 08, 2010 | Dell Inspiron 6400 Notebook
Mouse only moves up and down not side to side
If it is a PS/2 mouse with roller ball, the horizontal wheel sensors are gone. No sense in trying to fix this roller ball PS/2 mice are really cheap. As far as the USB mouse you may have to install a driver. Depends on the operating system.
Mar 02, 2009 | IBM NetVista M41 PC Desktop
In touch sensitive mouse in Dell 6000, I have problem
Move the mouse pointer to the right down or up arrow at the right bottom or top of the screen and press the button.
Hope this helps.
Good Luck.
Jan 04, 2009 | Dell Inspiron 6000 Notebook
Logitech wireless laser mouse will not move, pointer is stuck mostly on horizontal movement, won't go up or down, struggles to move in any direction really
change the batteries of the mouse if that didnt work.
try to clean the otycan head of mouse.
PLZ do RAte this post.
Dec 17, 2008 | Computers & Internet
Mouse pinter is partially moving
I would restart the computer, and if that does not solve the issue, I would replace the mouse.
May 12, 2007 | GE Wireless Optical Mouse
HEWLETT-PACKARD G62-347NR Laptop Logo
19 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
