Question about Toys
How could i use my iphone 4g to control my toy helicopter
  • 314 Answers
Instructions
    • 1 Remove the main rotor blades, throttle up the helicopter while holding it in your hand and twist the helicopter from side to side to determine if the gyro is working. The gyro should make the tail rotor spin faster when the helicopter twists; you will be able to hear a difference. If the gyro does not appear to be working, replace it. Some gyros have a sensitivity adjustment screw; try making small adjustments if possible.
    • 2 Check the tail rotors and see if they are connected correctly. If the tail rotor blades are not pitched correctly they will not be able to hold the helicopter still.
    • 3 Test the tail rotor motor and see if it seems strong and responsive. Brushed motors, like those commonly used to drive tail rotors, can wear out in a relatively short time. Replacing the motor may solve your problem if the gyro seems to be working.
    • 4 Check the trim on your transmitter. Ideally the trim should be in the center of the stick movement. You may need to dial in some extra right trim or you may find the trim is set too far to the left.
Posted on Jan 20, 2013
2 Suggested Answers
  • 906 Answers
SOURCE: find charger for world tech rc helicopter skyhawk
good day,
hope this link below will help tp solve your problem.
toys
Posted on Jul 29, 2010
Drone promark shadow wired diagram gps
Request the wiring diagram from the manufacturer/distributor.
May 03, 2018 | Parrot Ar Drone Rc Helicopter...
Why won't world tech toys phantom 3.5 ir helicopter charge?
check charger if faulty,,then check charging connecting jack in helicopter
May 14, 2014 | SYMA Toys industrial New Syma S107 Radio...
Helicopter slides sideways on takeoff to
All helicopters do even real ones you need to add a little collective.
If you have a 2 channel toy then the mainshaft may be bent or the flybar jammed.
Jan 01, 2014 | Toys
Do the helicopter itself have a on/off switch..tech-one gallant
After fights between teh kids (he's crashing my helicopter) I think I figured it out. The instructions says to select the frequency on the helicopter, but there is no switch. When you first bring up the helicopter and controller, sometimes the green light on the controller blinks a few times. That is it synching up with the helicopter. After you charge the helicopters, turn then both off, Then turn on one helicopter and one controller. The key is when the green light above the one off switch is blinking. I did it with trial and error, so I am not sure exactly how to get it in the mode where it is in pairing mode. RIght now I am reluctant to mess around with it because they are set correctly and the kids are playing with them. I will post later if I figure out the exact sequence for getting them in pairing mode
Dec 26, 2013 | SYMA Toys industrial New Syma S107 Radio...
Helicopter doesn't go above ground
Check that the helicopter is charging properly sounds like a lack of power.
Kind regards, Julian.
rccontrolfreak.co.uk
Feb 24, 2013 | SYMA Toys industrial New Syma S107 Radio...
Can't figure out how to change frequency on the S107 copter itself (not the controller). Can someone advise. Thx
Found this for you.
it appears that the helicopter dynamically configures the control channel upon first detection of a signal from a controller. So, If you 1) turn off the helicopter, then 2) turn on the controller, then 3) select the desired channel on the controller, then 4) turn the helicopter back on, then 5) hold the throttle down on the controller, the helicopter will start up (after a slight delay) and be controlled via the new channel.
Jan 04, 2011 | SYMA Toys industrial New Syma S107 Radio...
Bought a S108 helicopter. Charged the helicopter and lights are flashing but it looks like the remote control does not work. I have never seen the LED light on. Helicopter has not move an inch yet. I have...
There should be a sticker near the helicopters "on off" switch that has an "A" "B" or "C" on it. Make sure the switch on the controller is set to correspond with that letter. If that isnt it, keep it for parts and buy another. These are VERY delicate toys and most break quite easily.
Dec 27, 2010 | SYMA Toys industrial New Syma S107 Radio...
My AH-64 is out
No you can't change it you must get the right transmitter.
Jun 11, 2009 | SYMA Toys industrial SYMA S009 Micro...
Toys Logo
115 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
