Question about Honda Garden
Gxv120 where should the timing and the gear meet
  • Marcel brazeau Jan 25, 2013
    here is some more info on my problem i have a honda lawnmorer gxv120 and had to change the connecting rod and now i am not sure where the point on the timing should line up with the gear i really need help can you help thanks Marcel
    New Friend:
  • 30 Answers
If you are talking about the crankshaft to camshaft timing there should be a dot or indent on both gears. the correct alignment is the dots together through the centreline of crank and cam
Posted on Jan 27, 2013
Paper jam after fuser replacement.
Since you reset the counter you reset your paper size .the paper detection flag ,spring that returns it to its h ome position knocked off. Check all your connectors and make sure the drive gears are meeting up. Most fusers have what they call a pivot gear. It has a spring that engages it to the main drive . Make sure there meeting up. Tip ,mark a gear and make sure it rotates. White out works well to mark a gear. You could have a bad part.
Aug 18, 2015 | Brother MFC-9330CDW - Led Multifunction...
On the crank gear an cam gear do the dots meet when its TDC an both values are open on a 17.5hp mtd OHC lawn mower ser#1a276b30280. Mod#13bn771g729.
both valves are never open at same time!! the 2 dots should meet up at tdcbth valves closed, valve clearances should be approx .006-.008 inch
Mar 03, 2015 | Mtd Garden
Lawnmower tractor turns more to the left then to the rightt
look at the plastic connector where the steering shaft meets the main gear the plastic wears out and the gears jump out of time its a $15 part at sears parts online
May 25, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
When setting the timing on a 1980 chevy 350 are both gear supposed to be TDC at number 1?
Timing mark's on cam and crank should meet, if you did not put distributor out, just set timing gear's as shown, it you did pull it out, stab distributor 180 off, hope this was very helpful.
Aug 30, 2010 | Chevrolet 1500 Cars & Trucks
Looking for a timing belt diagram 2.4l dodge caravan changed timing belt tensioner but it is slightly bigger than the old one will this throw the timing off?
Sorry, can not fine a timing diagram, both cam's should read (up) at 45 deg., both timing mark's should meet at center, looking at motor, the right gear at timing mark st 9 o'clock, and left gear timing mark at 3 o'clock, the crank gear timing mark at about 1 o'clock, alidn mark on crank gear, with mark on housing, I hope this helps you, also the timing belt part number is Gates # T265.
Aug 30, 2010 | 2000 Dodge Caravan
No timing mark on camshaft gear 1995 2.2 corsica no. 1 cylinder at tdc.
There's a round mark or hole on the outer edge of both the cam and crank gear, align the cam gear mark at 6 o'clock and the crank gear mark at 12 o'clock so that they meet and your done.Good luck
Feb 25, 2010 | 1996 Chevrolet Corsica
I have a Murray Rider Mower with a Briggs & Stratton Engine Model number 287707. The Electric Starter gear turns, is not worn, but will not rise and meet the engine gear to turn the engine. Is...
try some wd40 on the shaft the gear rides on. work the gear by hand alittle it may just be stuck. usually if you dont have the power to spin the gear up the starter wont run at all
Nov 04, 2009 | Cars & Trucks
I need a diagram for a 94 oldsmobile cutlass supreme timing chain
There is a dot on each of the gears one on the large cam gear and one on the small crank gear.The crank gear dot on the teeth of the gear should point to the 12oclock postion straight up then the one on the cam gear point sin the 6 O clock position so the dots meet each other then you put the chain on the cam gear then around the crank gear then bolt on the cam gear the dots should still be lined up with each other.this puts the engine in the #4 firing postion
Oct 04, 2009 | 1994 Oldsmobile Cutlass Supreme
Difficult shifting through gears
I do a lot of mountain bike riding and there have been a few times where the gear changing hardware has definitely become bent rendering it nearly useless when it comes to changing gears.  Inspect the hardware very closely for any signs of damage.  Also be sure to look at where the gear shift cables meet the gear shifters on the bars.  Where it connects in you will typically find an adjustment knob (note that you may have the same type of adjustment knob where the cable meets the gear shift mechanism also) which the cable rides in.  You will make much larger jumps in adjustment when using this method as the screws on the gear changing mechanism, which you mention in your original post, are more for fine tuning.  Best of luck to you on te repair and I hope you don't need any new hardware!
Joe
May 07, 2009 | Cycling
Garden Logo
64 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
