Question about Singer 2277 Tradition Sewing Machine
Needle is stuck in SINGER 2277 Tradition - Singer 2277 Tradition Sewing Machine
3 Suggested Answers
bargainbox
  • 1388 Answers
SOURCE: bunching under fabric and needle stops
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Sep 01, 2009
Testimonial: "thank you that is alot of info. i ended up fixing it before i got your message but all that info will be alot of help and i thank you."
bargainbox
  • 1388 Answers
SOURCE: under fabric bunches of thread and the needle stops after seconds
TOP THREAD TENSION:
BOBBIN TENSION:
TOP LOADER:
FRONT LOADER:
back properly.
OTHER ISSUES:
Bargain Box
Posted on Sep 02, 2009
How do I adjust the timing?
Owner's manual is usually quite helpful. No manual? try MFG website, or their customer service email, or try manualslib.com
May 03, 2015 | Singer 2277 Tradition Sewing Machine
The needle has got stuck and does not come up when the handwheel is turned counter clockwise.
I would take it to the Sewing Shop. You've probably damaged whatever the needle has wedged itself into ...plus the needle and maybe the mechanism that drives the needle up and down.
Mar 16, 2015 | Singer 2250 Tradition
Hook timing ajustment on singer tradition
When the needle is going up, the hook point comes around and almost touches the needle at the back just above the eye, there is usually an indent in the needle just above the eye for the hook tip. the clearance is usually "almost touching by a hair"
The tip of the hook should be just coming out from behind the needle and the bottom of the point should still be at least a "hair" above the top of the eye... If that is not clear see image.f68312ec-ddb6-4007-b635-61d2971f650a.jpg
Apr 10, 2014 | Singer Inspiration 4206
How do I get my handwheel to work on my singer 2277 sewing machine the needle broke and the the handwheel won;t move
when the needle broke, it could have damaged some part in the machine and also the machine could have jumped time,, having the machine checked would be a good idea..
Sep 17, 2013 | Sewing Machines
My needle is stuck in the plate
needle has bend remove power from mains supply and remove the needle then fit new needle
Aug 04, 2012 | Singer 2250 Tradition
Singer 2277 manual
what is wrong with my machine the needle keeps jamming
Jun 07, 2012 | Singer Sewing Machines
I am sewing stretch jersey and my needle keeps breaking with a terrible noise - I have a singer 2250? any ideas?
you need to use a stabilizer because the needle is pushing the material into the bobbin shaft and jamming it. Clean it out and oil your machine. Insert a new needle and totally rethread.
Feb 27, 2011 | Singer 2250 Tradition
I cant get my bobbin to thread i have followed all the instructions it seems that the needle just isnt picking it up
Try to adjust the needle , enough to catch the bobbins thread and not too close to avoid breakage. The needle might be in a higher setting.
Nov 04, 2010 | Singer 2250 Tradition
Changing the needle
Loosen both screws and wiggle the needles out. change the new needle As a rule of thumb, the flat side of the needle always goes towards the opposite side of the last thread guide. So on your machine, since the last thread guide is in the front of the needle bar, the flat side of your needle goes toward the rear. The needle threads front to back.
Jul 29, 2009 | Singer 2250 Tradition
Singer 2277 Tradition Sewing Machine Logo
56 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
