Question about Ricoh Aficio 2015 Copier
Paper coming out from the tray is folded for richo 2015
Sir
I have a richo 2015 machine which has a reading of 1,08,700(number of print out taken)but lately the paper gets folded inside just above the drum. The matter does get printed on the paper but after that it get stuck inside and doesnt come out sometimes.This usually happens when 40 to 50 prints are taken continues. The person who repairs the machine says that the pressure roller has to be changed. Kindly could you advice me on this matter
  • 14 Answers
You do have a fuser problem. There are a set of stripper fingers that are supposed to keep the paper from wrapping around the heat roller. One of them may be damaged and is catching the paper. The Pressure roller can also cause problems if it is torn. You need to have the fuser looked at by a tecnician to determine the problem. Hope this helps.
Posted on Jan 28, 2009
2 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Richo Aficio 2015 I have
The pressure roller is inside the fuser section of the copier. If there is a flat spot on the roller, you will get those results. It's better to rebuild the whole fuser unit including the bearings and heat roller. That will stop that jamming from happening.
Posted on Jan 27, 2009
After replacing the main motor of my richo afico 2018 the copy result reduces is the cause of mismatch main motor?
Yes, If you have installed a main motor from Aficio 1015 the machine will work and there will be no SC Code displayed, but the machine will print a reduced image.
The part number for the main motor for Aficio 2015 is :
" AX06 0270 Brushless Motor 24V/20W "
Oct 05, 2013 | Ricoh Aficio 2015 Copier
When printing, the paper will start to feed and then pulls to the left, wads up and jams. This happens with both Tray 1 and Tray 2.
Hi You have a small paper jam in the front of your machine,
remove all the trays and the toners have a look under the machine in the place of tray 2 you will see a slot that the paper should feed in to. Fold a sheet of A4 in 1/2 lengthways push it in to the slot and with luck it will come out in the machine, holding on to both ends work the paper along the slot moving it up and down until your paper jam come out
if this is useful please rate me.
Mar 08, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
H2 error when printing from pdf to A3 in multipurpose tray
H2 error code means that the paper size you are feeding into the machine does not match the paper size programmed into the machine. Minolta's are picky about these 2 size matching. So if you trying to print onto A3 then when you select the multipurpose tray it must read as A3.
Here is the info from the factory service manual:
H2 The length of the paper set does not
match that of the paper actually taken
up and fed in.
• Load paper of the correct size again
according to the set paper size.
• Turn OFF and ON the Power Switch.
• For copier tray: Slide out and in the
paper tray in which the size error has
occurred.
• For Manual Bypass Tray: Place paper
in the Manual Bypass Tray.
• For Multiple Bypass Tray: Unload
paper from the Multiple Bypass Tray,
then reload it back again.
Nov 23, 2009 | Minolta Di152 Laser Printer
Cannot print a manal with the finished size as 5.5x8.5 folded and stapled. IT SHOUD PICK UP THE 8.5X11 PAPER AND FOLD AND STAPE IT BUT IT DOESN'T. Please HELP.
for the 8.5x11 paper to staple the paper has to loaded in the machine with the short edge of the paper fed first so if the paper is turned the wrong way in the paper tray the machine will reject the fold command it should say on the paper type setting 8.5x11R
Jul 21, 2009 | Konica Minolta Office Equipment & Supplies
Richo Aficio 2015 I have a richo 2015 machine which has a reading of 1,08,700(number of print out taken)but lately the paper gets folded inside just above the drum. The matter does get printed on the paper...
Jan 26, 2009 | Ricoh Aficio 2015 Copier
Printing problem with HP 2015 Laserjet Printer
If you have an adjustable paper tray, make sure that the tray is set for the right size paper. Also, you may have some type of sensor in or around the printer tray that tells the computer when the paper tray is empty. Sometimes these sensors get stuck and you have to free them up (very gentley).
Hope that helps - Ghost
Oct 27, 2008 | HP LaserJet P2015dn Printer
Brother 2040 paper light .. continuous red
If you removed a piece. But more remains it must also be removed. Look closely along the paper path for something that will release to provide access to the path.
May 03, 2017 | Brother HL-2040 Laser Printer
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Printing same page
try this make sure that receive reduction is switched on. You could load the paper tray up and just let it print as may have been a communication problem from RTI memory. Being Richo machine you should be able to reset the memory but this will get rid of all your stored numbers. But it will reset the machine so if you have a corrupted memory issue this will get rid of it.
Hope this helps you
Thanks J
Sep 11, 2007 | Ricoh 3310LE Plain Paper Laser Fax
Ricoh Aficio 2015 Copier Logo
128 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
