Question about Sewing Machines
Beldray sewing machine wont pick up stitch
Wont bring stich on way up
  • 106 Answers
SOURCE: grabbing and not picking up stiches
What is the make of machine
Posted on Apr 18, 2008
textile
  • 10 Answers
SOURCE: I have an Aldi Delta
sarah if the top tension is to tight it might slip stitches but as always when there is a problem with stitching you should change the needle and make sure it is in right.
Taking the needle plate of and cleaning with a fine brush around the bobbin and feeders will help and should be done regular.
Posted on Aug 19, 2008
kent581
  • 87 Answers
SOURCE: FEW STITCHES DROP IN BOBBIN
Dropped stitches troubleshooting:
1>change to a new proper needle (proper needle means quilting needles for free motion, stretch needle for knits, leather needle for leather, microtex needle for micro fabrics.....etc.) of proper size. Most sewers never need a needle smaller then an 80/12 when sewing. Smaller needles bend more easily causing more problems.
2>If a new needle doesn’t fix the problem, remove parts from bobbin case area (as best as easily allowable) and clean out all the lint thoroughly, and oil with 2-3 drops of oil where friction occurs (turn hand wheel and look for rubbing)
3>If still skipping, try a different spool of thread (Yes, thread can caused skipped stitches, not common but I see it).
4>If you haven’t solved it yet, sounds like you could need to make a lower level adjustment like hook timing.
Hook Timing:
To time the machine, you want the tip of the hook to pass just over the top of the eye of the needle when the needle is in the left most or right most position depending on which side the eye of the needle will be higher
Posted on Mar 21, 2009
  • 6 Answers
SOURCE: Bernina 440 stops stitching
see your local dealer and tell them you have a bad power board. or l-print. this is a known issue and bernina is covering it under there 5 year warranty. the 5 volt output is faulty on some some models
Posted on Apr 11, 2009
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
How to knit this, K2. K2tog, yfwdtwice. Sl1.K1.PSSO. K19
knit 2 stiches., knit 2 stitches together, bring yarn forward then over the needle and stitch like this twice, slip 1 stitch, knit 1 stitch, then pass the slipped stitch over the knitted stitch. Knit 19 stitches
Apr 27, 2017 | Sewing Machines
Beldray 12 stitch sewing machine manual
call or email these sites
sewvacdoctor.com
a1sewingmachines.com
Mar 04, 2014 | Sewing Machines
Machine wont pick up stiches
Please check the needle position and Stitch regulator. Or go to machanic shop.
Jan 06, 2014 | Sewing Machines
Beldray sewing machine won't make a stitch
try changing the needle--make sure the needle is the right one for
the fabric being sewed, and also inserted the right way in the needle
holder and all the way up into the needle holder
try rethreading the machine top and bobbin--make sure every
thread guide is used
make sure the bobbin is turned the right way in the bobbin case
if none of these suggestion help then the machine needs to be
checked to see if there is a problem with the timing.
Nov 01, 2012 | Sewing Machines
I have kanmore sewing machine its not stiches at all one time noise & stop stiches thered not pick up for bobin its not come out.
Wow. If I understand your attempt at English. Your machine made a noise and now won't sew or pick up the bobbin thread.
First change your needle and make sure it's full inserted and correctly oriented in the needle bar. Do a test stitch on scrap fabric.
If you still have problems.. check the timing. The shuttle hook should just be starting to pass the needle scarf when the needle is at the lowest point of travel.
I hope that helps you. Good luck.
Aug 20, 2012 | Kenmore 15218 Mechanical Sewing Machine
Need Manual for Beldray 0092 12 stitch sewing machine
try these sites you'll probably have to email about a manual
sewvacdoctor.com
Apr 22, 2012 | Sewing Machines
Stitches not forming correctly
the material may not be thick enough to make a correct stich, you might try interfacing with the single layer of material & see if that helps
Mar 05, 2012 | Kenmore Sewing Machines
No manual for a beldray 12 stitch sewing machine
hello how does the beldray sewing machine works? please email on alysha678@gmail.com if you know please
Feb 10, 2012 | Sewing Machines
Grabbing and not picking up stiches
Apr 11, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
