Question about Microwave Ovens
NN-SN960S panasonic microwave turntable turns when door open
Works fine and everything off when not in use and door closed, only issue is when door open continues to turn - slowly.
MicrowaveSvc
  • 9047 Answers
SOURCE: MICROWAVE TURNS ON WHEN DOOR IS OPENED.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food
/ grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic Microwave Turn table rotates when door is open
Found this Panasonic post in the Samsung section!
If it moves just a tiny bit when the door opens and then stops, that's normal.
If it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Any Panasonic parts not available locally can be had here: http://www.pasc.panasonic.com/epartr
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
  • 579 Answers
SOURCE: PANASONIC NN-S933BF 1300 WATT INVERTER
yes, get that fixed. it is a danger.
Posted on Jan 01, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic microwave nn-s548wav, No lights
This is likely a problem or loose connection on the control unit circuit board.
We regularly repair these for customers nationwide with our guaranteed $39.95 service.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 27, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: turn table/Spacemaker Microwave
TO jatcat007
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please feel free to contact me directly. (See below)
TO demps61
Chances are you have a bad door switch or loose door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
prototech@usa.net
Posted on Jul 06, 2008
Panasonic NN-SN960S turntable turns on when door is open
This can be caused by a defective door latch or possibly a control board fault.
Aug 28, 2016 | Panasonic Microwave Ovens
Panasonic NN-SN960S, turntable won't stop spinning. Have to unplug after every use. What kind of repair does it need and how much would it cost?
May be a door switch problem, or may be a control board problem. You might even have a shorted wire that goes to the turntable motor. (I have seen 1 of the wires get pinched and cut by metal guards or guides that were meant to keep the wires in place.) You can remove the screws from the bottom of the microwave oven, and drop the bottom panel down to checked for pinched wires. Unplug the microwave first before you do that.
Oct 18, 2014 | Panasonic NN-SN960S Prestige Stainless...
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
The turntable keeps rotating when the door is opened - Panasonic NN-T994SF
You probably have a shorted main relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic NN-T994SF Microwave Oven
Door shut off malfunction
I have the same problem starting yesterday April 19. Have you gotten any answers.
Mar 12, 2008 | Panasonic NN-T993SF Microwave Oven
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
