Question about Cell Phones
My g five d99 mobile update trick
Update trick
I have played high five casino on my iPhone for well over a year. As well as STS. But since my last update of High5 it will no longer load. Has the app outgrown my phone? What can I do to resolve ?
may be corrupt data, try reinstalling it after deleting it.
Your phones software may be corrupt....a hard reset of that and a reinstallation should do the trick if there is nothing wrong with the phone itself
Aug 01, 2015 | Cell Phones
How do I get the automatic updates that I had mistakenly declined?
Hello there are many ways to upgrade or update your handset software.like update from internet using wifi or gsm internet bundles.
or.....flash software by devices like as volcano.
you q?how do i get the auto updates that you had mistakenly declined........here some simple tec...first hard reset your mobile phone from factory settings.then go to store of your brand website.download upgrade and instal them in to your mobile phone.if your phone is nokia then nokia software updater...connect your phone via usb with your laptop or computer then apply this trick.
Remember one thing.......All browser have use cashe files for remember history please clean before all work you broser history and then apply as you access simple in your range.
thank i hope this is help full for you for more information please visit my blog for mobile hardware and software help.http://phonetolls.blogspot.com
Mar 05, 2015 | Samsung Galaxy GT-S5570
This is problem in my laptop -- Windows Script Host -- Loading script "C:\WINDOWS\:Microsoft Office Update for Windows XP.sys" failed (The filename, directory name, or volume label syntax is incorrect. ).
Microsoft has stopped providing XP users with security updates, forcing them to either upgrade to another, newer operating system, or gamble with their safety. While the latest usage figures show that a large portion of users are moving away from XP, there's still a sizable number of users who aren't -- or can't.
If you're an XP user, or know some XP users, there's a trick which makes it possible to receive security updates for the aging OS for another five years -- right up until April 2019.
The workaround makes use of updates for Windows Embedded Industry (formerly known as Windows Embedded POSReady). This is based on Windows XP Service Pack 3, and the security updates which are being released for it are essentially the same ones Microsoft would have pushed out for XP, if it was still doing so.
You can't simply install the updates -- that would be too easy -- and you'll receive a version mismatch error if you try. But a simple registry tweak is enough to fix that.
Create a text document, and call it XP.reg. You'll need to make sure .reg is the proper extension -- so not "XP.reg.txt". If it's not showing up as a registry file, open any folder, go to Tools > Folder Options, select View and uncheck 'Show hidden files and folders'. That should fix the problem.
Right-click the file, and select Edit. Paste in the following:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\WPA\PosReady]
"Installed"=dword:00000001Save it, and then double-click the file. That will make that change to the registry. That's all you need to do. Windows will now automatically fetch updates designed for POSReady 2009, ensuring XP remains protected for the foreseeable future.
This trick only works for 32-bit editions of XP, but there's a workaround for 64-bit versionshere.
Naturally, there's no way of knowing how long this trick will work -- Microsoft could put a stop to it at any moment. Also, because you're installing updates for a system other than Windows XP, there's the possibility that not all updates will work as intended. But it's still worth a shot.
Apr 04, 2013 | Acer Computers & Internet
How 2 update my nokia n72 firmware. reason my nokia n72 phone will not format with this set up-*#7370# . pls help me
Have you tried this trick. Press and hold * + green key + 3 + power ? if not you can see the details from this link Formating tips of Nokia Mobile phone.And to update your phone Click here1.If you need further information just leave a comment.Good luck.Thanks for visiting fixya.
Sep 26, 2011 | Nokia N72 Cellular Phone
My computer security updates fails all the time with numerous codes: Security Update for Windows XP (KB2555917) Security Update for Windows XP (KB953155) Security Update for Windows XP...
Check this answer at answers.microsoft... it may be as simple as turning off your antivirus while installing these update. You may also try the installation in Safe-mode.
Aug 09, 2011 | Computers & Internet
Connecting floor speakers s-d99 to vsx-515. Why is it on negative numbers?
If it is the Volume you are referring to as being negative numbers, that is because the volume level is shown as a decibel level, e.x. -4.0 dB all the way to 0.0 dB. Most receivers show volume this way, and is nothing to be alarmed about.
Jun 25, 2011 | Audio Players & Recorders
Sony ericson w580i
Well the update did not do the trick what you may have to do now is reflash the firmware on the phone to correct this issue so take the phone to a mobile service center and have this done there.
Sep 06, 2008 | Sony Ericsson W550i Cellular Phone
Need to change iPod from Windows format to Macinotsh format
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod.five_rs/
I think restore might do the trick. follow the instuctions, Ipod video / ipod classic.
If you need more assistance let me know. Good luck.
Mar 29, 2008 | Apple iPod MA446LL/A MP3 Player
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
