Question about CaptiveWorks 800s Fta Satellite Receiver
My cw-800 is giving weak signal for channels 300 and up when the signal for both satellite 119 & 110 echo star are good what i could do to fix this?
Nothing is wrong with both signal there are over 85% strength but when you try ti view some channels of one of this sat. it appears weak signal.
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
hartpark
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, ray.calo@dishnetwork.com. If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
Hello- using dish 500 with twin lnbf, 311 receiver. 119 locked in easy with 70 signal . When trying to find 110, I cannot get a strong enough signal to lock. 129 signal shows strong along bottom of point...
Hi CharlieO my name is Mike of DISH Network and I was reading over your post and seenwhere your 110 satellite is not locking in or on your install summary screen. Iwould be more than happy to help with this issue and to research further I willneed to look at the account to look what satellites they have setup on youraccount. I will need your account number or your phone number; I will leave mye-mail so you can contact me directly. Michael.houston@dishnetwork.com
Jan 30, 2011 | RCA DISH Network(r) 311 Satellite System
Dish Network 322 will not work both TV's at the same time. If TV1 is on it works fine, but TV2 says aquiring satellite signal. If TV2 is on it works fine, but TV1 will say aquiring satellite signal. Both...
Hello! Dan Busa with Dish Netywork here intermittent signal loss like that is usually caused by some sort of glitch a hard reset ( unplugging it for ten seconds ) will usually resolve this. If your signal strength is at or above 80 that should be fine, but keep in mind you need good signal strength on both the 119 and 110 satellites ideally you should be at 70 .
Jun 25, 2010 | DISH Network 322 DTV Receiver
Can't get Dish500 satellite system set-up
If you tripod or mount is perfectly plumb and you have the correct information for the settings at your current location then you may have a faulty piece of hardware ensure all connections are tight and that all bolts on the dish are tight. Once you get 119 try gently pulling on the top of the dish and see if that increases the signal stregth and gets you 110 since it is at a higher elevation than 119. let me know if this helps.
Thanks for using Fix Ya.
Dec 03, 2009 | DISH Network ViP 211 DTV Receiver
No signal on one tuner for dual tuner box.. neither tv works.
Hi benray there is something else youcan do on that to make sure your getting the strongest signal possible. Youwill need to press the MENU-6-1-1 buttons on the remote. Select Check Switchand Test, after the test is complete select done and then check the signal andif there is still a weak signal we will need to re-point the Dish.
Oct 24, 2009 | DISH Network 322 DTV Receiver
Fta viewsat 2000 setup problem
You will need a sonicview or viewsat switch spliter 110 port 1 119 port2 then go into your menu and ajust the settings 110 tp is 12258 and 119 is12239 and make sure you have the freq on the correct setting11250 scan each alone then save.Also set what typelnb you have on there to hope i helped
Dec 17, 2008 | Yamaha HTR-5730 Receiver
Dish Network - Dish 500 Satellite 110 is not being recognized
chances are that you have only lined up the dish to pick up one satellite. there are several satellites up there for dish and its easy to miss the ones that you need. try to line up the dish keeping this in mind. if that doesn't work, write back.
Apr 30, 2008 | Televison & Video
Hi. I need help finding 119!
I looks like you are picking 110W with the LNB on your left if you are facing the dish.
Try to get 119W first if you connect the cable to the 119 LNB, once you find 119W that way, you will also have 110W.
Good Luck.
Feb 24, 2008 | RCA DISH Network(r) 311 Satellite System
Dish network 119
you cannot satellite sginal from a splitter you will need dp 34 switch or quad LNBF DP HOPE THIS HELPS.
Jan 12, 2008 | RCA DISH Network(r) 311 Satellite System
Lonnie, You have a simple problem,the 119 satellite is lower in the sky than the 119 if you make sure the pole you are mounted on is straight and plum ,then simply raise the dish a few elevation degrees and turn the dish to the left.Your dish is aimed low and to the right.
Oct 18, 2007 | RCA DISH Network(r) 311 Satellite System
CaptiveWorks 800s Fta Satellite Receiver Logo
49 people viewed this question
Top CaptiveWorks Televison & Video Experts
Are you a CaptiveWorks Televison and Video Expert? Answer questions, earn points and help others
