Question about Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi Aquapulse DE 6543 X
Doesn`t heat
3 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: is my zanussi aquapulse de
It is more than likely hot water fed. You can trace the line probably to under your kitchen sink and see where the line follows up to your hot/cold on your sink. There would be then another line coming off the hot which would lead to your dishwasher.
Posted on Jan 17, 2009
SOURCE: The Zanussi Aquapulse (de 6965) Fault Code AL3.
Eureka! thank you FixYa. My Zannusi de6965 was failing to heat up andf finish the programe and showing Al3 read a number of your contributers and after stripping down the front of the DISH WASHER found my way into the main circuit board and there they were 2 two DRY JOINTS ( where the blue and orange wires connect) cleaned and re-soldered then re- assembled and tested.... Eureka! it worked just fine.Remember to take care when disconnecting the internal wiring from the circuit board. I colour marked each connector block and made a drawing. Thanks again hope this helps.
Posted on Jan 02, 2012
My Zanussi aquapulse de 6654 will not start. Only the on/off switch light lights.
Hi, I have a zanussi de6965 had the same problem the only indicator light that works is the on-off button.I had a problem some years ago with my machine would not work and showed L3 as the fault as I remember. I was advised to switch off all power isolate from the wall is best(pull the plug out of the socket) I removed the front casing held along the top and down the inside by a number of small screws. You need to leave the two bottom screws in(one each side) Wiggle free the top half of the display panel to acess the box holding the PCB board.it's very fiddly you will need a sheet of paper and a pen to make a noet of the connecting sequence of the wires ( Mark the blocks of wires with numbers... when replacing everthing this should eliminate any problems) Remove the PCB board from its casing and turn over to expose the back. At the bottom left hand side I discovered two dry joints, I needed a magnifing glass to check all the joints just incase. The faulty joints were a little discoloured blackened slightly. Solution...I cleaned, fluxed and re-soldered the joints. When re-assembled all the parts. It will help when dismantling to keep a note of the number and size of the screws and where they were removed from.
My dishwasher is now working again. hope this helps.
Sep 23, 2011 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi 6543 not heating water and not drying
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Oct 24, 2010 | Dishwashers
DE 6850 not drying
heatman101
Sep 16, 2010 | Zanussi 24 in. DE6850 Free-standing...
Zanussi Aquapulse DE6854 dishwahser programe lights not working
hi
got same probleme with my aquapulse 4744 slimline
Oct 07, 2009 | Electrolux Dishwashers
i have this now- another site suggested its the heater, or rater the circuit board. I have just taken it apart and have two dry solder points that are identified quire easily by soot around the area. so now off to find my soldering iron!!
Sep 26, 2009 | Zanussi 24 in. DE6965 Built-in Dishwasher
Is my zanussi aquapulse de 4744 dw hot or cold water fed ?
Jan 17, 2009 | Zanussi 18 in. DE4744 Free-standing...
WATER NOT HEATING IN MODEL DE 6850 Zanussi DISHWASHER
YOU NEED TO LOCATE THE THERMOSTAT AND CHECK IF ITS WORKING CORRECTLY IF THE READIND ON THE STAT IS FINE YOUR ELEMENT MIGHT BE FAULTH.BEST YOU GET A TECH TO ASSIST YOU AS ITS A TUFF JOB TO DO ALONE.
GOODLUCK.
MOHAMED
Sep 19, 2008 | Zanussi Dishwashers
Dishwasher zanussi aquapulse
this sounds lie a door interlock, in most models this is a micro switch where the handle is inside the top of the door casing, i would start there, based on the info that you have given
Sep 19, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi Aquapulse DE6544 not emptying
Zanussi Aquapulse dishwasher - is filled with water inside, is not washing and the lights keep flashing on and off - has anyone any idea what may be wrong with it?
May 27, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Stopped Working
The problem is with the PCB, this is the board behind the buttons, you can buy this for £120 or you can get it fixed by QEA for about £45 link below. I am not an engineer but I replaced mine in 10 minutes.
http://www.qualityelectronicrepairs.co.uk/lists/laundrymodels-zanussi_1.html
Sep 25, 2006 | Zanussi 24 in. DE6744S Free-standing...
Zanussi 24 in. DE6965 Built-in Dishwasher Logo
211 people viewed this question
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
