Question about Dryers
Have a harbor breeze remote to a harbor breeze fan ,# 0003497. Grandson messed with switches in remote so now we need to know the code. Please help. Thanks.
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
SOURCE: installation of wall remote for harbor breeze ceiling fans
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
Posted on Nov 25, 2008
SOURCE: Fan Speed Too Slow
You need to pull the fan chain until it is set to the fast setting, then you use the remote to set the fan at the speed you desire.
Posted on May 28, 2009
SOURCE: Harbor breeze fan will only work on low speed
I'ts not a transformer, it's a capicator and could be bad. call Harbor breeze with model (on top of motor assy) and they can sell you the correct one.
Posted on Sep 25, 2009
SOURCE: I need a spare parts for a Harbor Breeze remote
Where can I purchase a capacitor for harbor breeze
Posted on Feb 02, 2010
Installed 2 remotes, 1 in each bedroom. second remote learned both fans and now controls both. How can I fix this? Will these remotes UNLEARN a code?
most likely both fan/remotes are set with the same code. You should be able to put each on a separate frequency. Normally there are small switches that are used to set the codes in the fan and the controller.
Jul 16, 2015 | Televison & Video
Harbor breeze ceiling fan w/lights&remote
Did the fan have a remote when it was purchased? If so, you already have a receiver in the fan somewhere. You'll have to find it to see if you can set the new transmitter to the same frequency.
Jul 23, 2013 | Dryers
Harbor breeze ceiling fan remote does not work
You need a new receiver. Harbor Breeze is a store brand made with low-end parts.If you want airflow you need to get a fan with at least a 13 degree blade pitch. Remember you get what you pay for.
Jul 07, 2013 | Dryers
Need manual for harbor breeze fan model # LP8063
The remote went bad, this is very common. These are great fans with poor design and cheap remotes. Go to Lowe's buy the new kit ( model: RCE-103LW) $30 bat included. Put battery in and turn off light switch. Have a bic pen ready with the battery cover off. Turn on light switch and press "learn" red button with the pen . You will have to hold it down for about 5 secs. The fan will the turn on medium if it took to learning the new remote. All buttons should now work normal. Return old remote to store for exchange they have a 1year return to to store warenty per the company rep. Anyother problems call 1 800 527 1292. They have good cust. Service.
Jul 21, 2012 | Dryers
My Harbor Breeze remote control fan no longer responds to my remote controller. The first sign of problems was when the lights began flickering momentarily when I tried to dim them. Then the lights went...
this black box is a watt governor for the lights. just remove it, and wire direct. then you should be fine, just let me know the outcome!! the box should have vent slots in it. part # for hunter fan. i do not know if its the same as harbor breeze. --- part # 98480-02, this is what makes lights flicker. if need be replace remote. go to www.harborfans.com and click on support to find phone number for assistance. have a good day !!
Dec 15, 2010 | Dryers
Installation of wall remote for harbor breeze ceiling fans
Nov 17, 2007 | Dryers
Dryers Logo
22 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
