Question about Dell TrueMobile 2300 Wireless Router (tm23003)
How to rename dell truemobile 2300 wireless router?
Joed911
  • 4338 Answers
SOURCE: How do I set up a password to secure my wireless network??
Enabling the WEP for the Dell TrueMobile 2300 Wireless Router
Click the Start button.
Click All Programs.
Click Internet Explorer.
The Internet Explorer browser window appears.
Type the following in the Address line:
192.168.2.1
Click the Go button.
You are prompted for a Username and Password.
Type the following as your username:
admin
Type the following as your password:
admin
NOTE: If you previously changed your administrator password in the advanced settings of the router you will need type the password that you set.
Click the OK button.
The Dell TrueMobile Setup Page appears.
Click the Basic Settings tab.
Click the Wireless Security button on the left side of the page.
The Wireless Security window will appear.
For the highest level of security choose the 128 Bit encryption option.
You will have to type a name for your encryption key in the field to the left of the 128 Bit option.
Click the Save and Restart button on the left hand side of the page.
The Save and Restart window appears.
Click the Save and Restart button.
Your settings will be saved to the router.
More Secure
Configure the 2300 Wireless Router for WPA-PSK with TKIP Encryption.
Double-click on Internet Explorer.
The Internet Explorer window appears.
In the Address Bar type my.router or the default IP address 192.168.2.1.
Press the <Enter> key or click Go.
The TrueMobile 2300 password window appears.
Type the User Name and Password.
NOTE: The default user name is admin and the default password is admin.
Click OK.
The TrueMobile 2300 Wireless Router configuration window appears.
Click Basic Settings.
Click Wireless Security in the left-hand pane.
Click to select Enable Wireless Security.
Under Network Authentication, select WPA (Wireless Protected Access) from the drop-down menu.
Input a network key or password in the field to the right of WPA Pre-Shared Key.
NOTE: Your network key or password can use 8 to 64 characters using Hexadecimal digits or 8 to 63 characters using ASCII characters.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 02, 2008
  • 44 Answers
SOURCE: Change password on Dell TrueMobile 2300 router
Hi, logon to your router using IE or whatever browser. Then follow these steps and let me know.
Type the username: admin
Type the password: admin
Click the Advanced Settings tab.
A note appears stating that Dell provides the advanced features for your convenience only. Dell technical support representatives can not support the configuration options in the Advanced Settings portion of the setup program.
Click the Administration Settings button on the left side of the page.
Put a check in the box to the left of the Change Your Password setting under the section of the page titled Password Settings.
Type the password that you want to use in the New Password field.
Retype your password in the Retype Password field.
Click the Submit button.
Another window appears stating You have successfully submitted the settings to this device!
Your new password will be saved into the router settings.
Posted on Nov 29, 2008
  • 73 Answers
SOURCE: Dell Truemobile 2300 - cannot connect to internet
This is usually a router configuration issue. The router has to be configured to match your new broadband settings.
For example, your old DSL may have required some kind of login which was entered into the router. For most broadband cable connections, you set the router to get an IP address automatically.
Re-run the router Setup Wizard. You can download it here:
http://ftp.us.dell.com/network/R74885.EXE
Posted on Feb 06, 2009
  • 256 Answers
SOURCE: Setting up a w.less repeater using an old w.less b.band router
Temporarily plug in wire network cable into Dell and log into Dell.
1. Set wireless up the same as the Belkin. Save these settings.
2. Set WAN to "Static IP Address and give it an address about 25 higher than Belkin. (Belkin 192.169.0.1 - Del 192.168.0.26). Save these settings.
3. Disable DHCP and Save these settings.
Exit web browser and disconnect network cable. Restart your complete system, first the Belkin, then the Dell, then your computers.
This way, the Belkin is running and able to assign IP addresses to all that start after it.
Posted on Jun 11, 2009
arvinds88
  • 108 Answers
SOURCE: How do I open ports 500, 4500, 53, and 52428 on Dell TrueMobile
1.Open the router interface by checking the default gateway
2.Under FIREWALL, you can find an option that would say "Virtual Servers"
3.Enable these ports, along with their types(TCP/UDP/Both) and assign an IP address that your Verizon Network Extender is going get( you to set that manually on the verizon device)
Save the changes and the ports will get forwarded!
**Note: In this case, DMZ under FIREWALL will NOT work!
Posted on Jan 18, 2010
Where is the wps button
some routers dont have wps button but if you need to reset router To restart the Dell TrueMobile 2300 Wireless Broadband Router, unplug the power connector and plug it back in.
To load the Dell TrueMobile 2300 Wireless Broadband Router's default settings, hold down the reset button on the router for at least five seconds. While the unit resets, the Power light blinks.
Jan 06, 2013 | Dell TrueMobile 2300 Wireless Broadband...
Cannot get truemobile 2300 to communicate with linksys usb network adapter Wireless light does not show in truemobile 2300 and link light does not light up on network adapter
To isolate the problem try installing the adapter to a different computer and if it works there it could be that your card slot is defective. As for the router try to reset it
Mar 06, 2010 | Dell TrueMobile 2300 Wireless Broadband...
Trying to hook up dell truemobile 2300 wireless broadband router model wx-5565d
Well dell has ther online chat support team which is only avalibe intell 5 PM during the day only.
Jan 19, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Network key for truemobile 2300
need more information for your problem.
Oct 16, 2008 | Dell TrueMobile 2300 Wireless Router...
Truemobile 2300 wireless router
tm1972:
Please consult the manual to reset the router to factory defaults this will give you full access to the router and this way you can reset PPPoE, check this out:
http://www1.ca.dell.com/content/topics/reftopic.aspx/gen/en/truemobile?c=ca&cs=cadhs1&l=en&s=dhs&~tab=3
Hope that helped!
Dec 10, 2007 | Dell TrueMobile 2300 Wireless Router...
Before you throw it, save all the settings in router and try a re-start or there is normally a re-set button somewhere to press and set it back to factory settings. If the wireless re starts re-load previous settings. Please rate solution.
Nov 15, 2006 | Dell TrueMobile 2300 Wireless Broadband...
If you are able can you reset the router in any way normally little reset button on back, or get into the routers set up page and try a restart.
Oct 29, 2006 | Dell TrueMobile 2300 Wireless Router...
Dell TrueMobile 2300 Wireless Router (tm23003) Logo
22 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
