Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Can't connect Samsung VCR DVD combo
I have the Sony Bravia KDL-32L4000. I’m trying to connect a Samsung VCR & DVD combo. I have the S-video and audio/video cords from the “line out Audio R, Audio L and the S Video” on the VCR/DVD player. These cords are plugged into the “Video in S-video, Audio R, and Audio L”. The cable cord is going from the wall to the TV. The TV menu has a setup and I have set the Video 1 to VCR to match where the cords are plugged into the TV.
    Problem Solver:
  • 10 Answers
This will only workif the vcr has a up convert feature whit out up convert it will not work you will have to connect vcr whit yellow red and white cables then dvd and vcr will give u the picture, if u connect dvd with commponent cables if u tv has this input picture from dvd will be better
Posted on Jun 16, 2009
TV= Sony Bravia Model KDL-48W600B and a DVD?VCR Recorder VCR What is the Proper connecting ports between the TV and DVD/VCR Recorder?
See this link to a You Tube video explaining how to connect a VCR to a newer TV. There are both coax and composite video explanations.
https://www.youtube.com/watch?v=zgb7uoLIaQE
Jul 22, 2015 | Sony Televison & Video
DVD and VHS don't work
The outputs of your VCR/DVD player should be plugged into the audio and video inputs of your TV.
Mar 09, 2014 | Sony BRAVIA KDL-46W3000 Television
KDL-32L4000 firmware
Contact the authorized service center for Sony. They will provide you software by USB.
May 30, 2013 | Televison & Video
How do I re-connect a VCR/DVD player to a Bravia? I have (!) video output and (1) audio output wire from the VCR unit and have tried a number of combinations without success connecting to the back of the...
The DVD/VCR player should have video (Y) plus right (R) and left (?) outputs that connect to corresponding inputs on the rear of the Bravia TV. You should be able to press the TV/VCR button on the remote to select that device as the input source.
Mar 17, 2017 | Sony BRAVIA KDL-20S3000 20 in. LCD TV
I have a kdL-32L4000 bravia tv that just started showing a lower ghost picture I have tried the reset and video adjustments, with no luck
The T-con board or LVDS cable fails, may be bad connection. You can try to reseat them first.
There are some pictures for reference http://tvhelp4u.spaces.live.com/default.aspx 95a93cd.jpg
May 19, 2010 | Sony Televison & Video
Sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Dec 02, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have a Bravia. None of the set up diagrams show a setup with a
I went where I made the purchase. It turned me off when I would have to pay you for the information that should have come with the instruction booklet. Bob
Jun 05, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony TV KDL-32L4000 Turns Pink
My Sony tech says it's most likely a bad cable box. Try a DVD and if the DVD is fine then it's for sure your cable box. Needs to be replaced by the cable company.
May 06, 2009 | Sony Televison & Video
When I got my Sony BRAVIA KDL-32L4000 last year, I could not get my VCR to work  in Video In-2 on the side of the unit. Got a consistent "no signal" message on the screen. I then got rid of the old...
If you take the cables that are currently connected to video 1 and connect them instead to video 2, select video 2 as the input from the remote and get the no-signal message, there is a problem with either the switching IC (not likely) or the input jacks (more likely). The problem with the input jack may be as simple as a bad solder connection that can be fixed in 5 minutes. Do the test first. If you get no signal, request service. This should be a simple repair.
Dan
Jan 13, 2009 | Televison & Video
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
327 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
