Question about Homedics SC380 Scale
Can't remove battery for replacement. where is the release?
How do remove the battery from the ryobi lawn mower when the release latch isn't releasing?
blow around it with some compressed air, you've got dirt or debris in it.
Oct 04, 2014 | Garden
Tip
Dyson Cool fans and Hot + Cool heaters - Replacing the remote battery (Screw...
How to replace the battery in your Dyson Cool fan or Hot + Cool™ heater. This applies to remotes which include a base held in place with a screw.
If your remote control's signal range deteriorates, you made need to replace your remote's battery. Remove the screw from the base to release the battery. Please use battery type CR 2032.
Do not install backwards or short circuit the batteries. Do not attempt to dismantle or charge the batteries. Keep away from fire. Follow battery manufacturers' instructions when installing new batteries.
on Nov 27, 2014 | Dyson Dryers
Nook won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 14, 2012 | Barnes & Noble Nook Simple Touch eBook...
Battery fully charged, car wont start, cant remove key, 2004 cadillac cts
There is a magnetic switch on the 'park' position. The car only starts or releases the key in 'park' is enabled. Maybe this switch is not working! Try to replace it!
Apr 11, 2012 | 2007 Cadillac CTS 3.6L
Password for phoenixbios 4.0 release 6.0.5
If you've lost the bios password, you'll probably have to 'flash' the bios. If you feel comfortable enough, you can dismantle the laptop and remove the motherboard battery for several minutes, then replace it and reassemble the system, see if the password has been cleared. (Note: The motherboard battery is NOT the laptop battery; you have to remove both!)
Dec 12, 2011 | IBM ThinkPad A21m 2628 Notebook
I need to change my6 battery
Hi Robert.
In Buick models built before 2002 the battery is located under the hood, in the lower left hand corner of the engine compartment. To replace the battery remove covers, detach the positive cable and put it out of the way. Do the same with the negative cable (make sure you secure cables away from battery terminals).Undo the screws securing the holding rod and release the rod enough to remove the battery. Remove holder and free the battery.Perform operations in reverse order to install the new battery. Always connect the ground cable to new battery before connecting the positive cables.
NOTE: You asked the question listing a 1993 vehicle. Newer models have the battery located under the rear passenger's seat bench. It is necessary to remove the seat's cushion to access the battery. I
Regards.
Ginko
Aug 31, 2011 | 1993 Buick Regal
Wont turn on
1.Plug the Inspiron's AC power cord into a power outlet and try to power on the laptop again. By far the most common cause of a laptop's not powering on is a dead battery.
2.Plug the AC adapter into a different outlet to check for a "dead" outlet. If you have the cable plugged into a surge protector, plug the cord into a different slot on the surge protector or "bypass" the surge protector by plugging the cable into an electrical outlet. If the Inspiron now powers on, replace the surge protector or have an electrician examine any "dead" outlets in the home.
3.Open the battery bay on the underside of the Inspiron by sliding the battery bay latch release lock upward and the battery bay latch release to the right. Once both latches are released, the battery bay should open.
5.Purchase a compatible replacement battery for laptop. Be aware that using an incompatible battery can cause damage to your computer. If you have any doubt as to compatibility, the best option is to purchase the replacement battery directly from your laptop's manufacturer.
6.Install the new battery by following the battery-removal procedure in reverse order. Once the new battery is installed, try again to power on the laptop. If there is still no power, seek professional repair advice.
I hope you find it very helpful.
Aug 25, 2011 | Gateway Computers & Internet
Replacing battery on Aston Martin Vanquish
Below is the procedure for an Aston Martin Vantage, perhaps the vanquish is similar?
Removal
1. Power the driver's fully forward.
2. Remove rear compartment cover.
3. Loosen and disconnect battery terminals, earth (- ve)
terminal first.
4. Release rear carpet, studs (x2), move carpet aside.
5. Remove screws (x2), battery compartment cover to
support rail.
6. Remove nuts (x2), battery compartment cover to body.
Remove cover.
7. Remove Torx screws (x4), remove battery clamps (x2).
8. Disconnect battery vent tube.
9. With assistance, remove battery.
Installation
1. Clean battery tray and clamps.
2. With assistance, install battery into its compartment.
3. Connect battery vent tube.
4. Position battery clamps (x2), install and torque tighten
Torx screws (x4).
5. Ensure battery vent tube is not distorted by battery.
6. Install battery terminals, tighten terminal nuts to correct
torque.
7. Install battery compartment cover, install and tighten
screws (x2) and nuts (x2).
8. Position rear carpet, secure with studs.
9. Install rear compartment cover.
10. Reposition driver's seat.
Courtesy of pistonheads.com
Please vote if this helps! Thanks, Mike
Jun 12, 2011 | Aston Martin Vanquish Cars & Trucks
I have a TI84 plus texas instruments i have removed both the batteries in order to reset the unit but it still has not resetted the unit. All I am getting all zeros on the screen
First try removing all four AAA batteries and the small lithium backup battery (above the four AAA batteries). Leave all batteries out for five minutes, then replace them and try to start the calculator. If this doesn't work...
Replace all but 1 AAA battery. Press and hold the "CLEAR" button on the calculator. While holding the "CLEAR" button down, replace the missing AAA battery. While still holding the "CLEAR" button, turn the calculator on. The display should read "RAM Cleared". Release the "CLEAR" button and press again to remove the message.
If that doesn't work, remove 1 AAA battery again. Repeat the preceding instructions with the "DEL" key: With the battery removed, press and hold the "DEL" key. With the "DEL" key held down, replace the battery and turn the calculator on. The screen should say "Waiting... Please install calculator software now." Release the "DEL" key. Download this program onto your computer (from Texas Instruments). Connect the calculator to the computer using the USB cable provided with purchase. Run the TI OSDownloader program and follow the on-screen instructions to re-install the calculator's operating system.
Apr 30, 2011 | Texas Instruments TI-84 Plus Calculator
How to replace the battery on the polar f55 watch. I have the back off but do not see how to remove the battery.
The idea that you cannot change the battery yourself is nonsense.
Remove the 4 screws from the back. (A size #000 screwdriver works well.)
To remove the battery latch, stick a small, flat-blade screwdriver in the hole shown below:
Pry the metal tab away from the battery and the latch will release.
The battery is a CR2032. Note that the + is face down. To replace the latch, just push the open end back into place. It will click closed easily.
When replacing the back cover, take care to make sure the seal is positioned correctly inside the groove.12_8_2011_4_41_24_pm.png
Replace the 4 screws and you're done!
Sep 30, 2009 | Polar F 6 Heart Rate Monitor, Coal
Homedics SC380 Scale Logo
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
