Question about Toto Neorest 600 1pc. Toilet MS99OCGR-01
Neorest installation instuctions bowl - Toto Neorest 600 1pc. Toilet MS99OCGR-01
3 Suggested Answers
  • 244 Answers
SOURCE: the bowl is full of water and cannot be snaked by
When you say it does not flush; do you mean it flushes...the water just won't go down (won't empty the contents of the toilet bowl)?
Be more specific.
JZ...
Posted on Dec 10, 2009
  • 67 Answers
SOURCE: I have a Neorest 550 brand new. It wont clear the
Ensure the water supply is opened to full. This unit needs the max water pressure available to work properly. You can test the water pressure by running the water into a bucket at full capacity for 10 seconds from the cold water supply for the toilet. If you get 1.5 gallons or more then you have sufficient water pressure. If your water pressure is good remove the water filter from the toilet and ensure it didn't get clogged with something during installation. The other 2 possibilities are that the toilet is defective and requires repair or replacement or the wax ring may be obstructing the water flow. Try the simplest things first. I would also contact the manufacturer to trouble shoot with them as well.
http://admin.totousa.com/Product%20Downloads/H06939R%20NEOREST%20550%20BOWL%20UNIT%20ENGLISH,%20IM,%20V.01.pdf
Customer Service & Technical Support
Tel: 1-888-295-8134
custservice@totousa.com
techsupport@totousa.com
Posted on Aug 03, 2010
Djusted or must it be replaced?nearest fill valve shuts off before toilet bowl fills.
You may be experiencing a valve issue. Of course, it could be any problem. It's really hard to tell with toilets. I would check the water level first and add water into the tank if it looks like it doesn't satisfy it's system. My toilet gives me a lot of trouble and I am constantly calling for plumbing services. However, a lot of times when I'm having issues I'm able to fix it momentarily by adding water or pulling the chain link my self. http://absolutelyclearsewersandplumbing.net/Services
Oct 14, 2014 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
Toto neorest 500 take two flushes to work properly
Water pressure may not be strong enough or the tank is not filling up well in the back.does it have trouble on just flushing urine.
Jan 13, 2013 | Toto - Toilet - One-piece - Neorest 500 -...
My neorest 500 smells we have had it for 4 years. I am wondering what can be done. we love the toilet.
Smells usually come from the tank and not the bowl.
Buy tank deodorizer from local store located near toilet brushes.
http://secure.willert.com/images/bf_wire.jpg
Deodorizer hangs inside tank. make sure it reaches the water.
You can also drain and clean the tank using CLR calcium lime and rust remover.
The CLR and gunk are fine for flushing away as long as the gunk doesn't clog the flush holes that let water flow into bowl.
http://www.fixya.com/support/r6633961-toilet_doesnt_flush_water_just_spins
Sewer line can also cause of odor.
If the toilet bowl is not full of water, or if nearby drain is not filled with water, or if toilet is not sealed tight against floor, or if toilet appears to have dampness visible around base, or if a vent pipe terminates behind a wall instead of on the roof: these things can cause sewer air to enter room.
Jul 28, 2011 | Toto - Toilet - One-piece - Neorest 500 -...
After automatic flush, water continuously runs into bowl. The water is coming from the upper bowl above the wand area.
i would think the syphon is not closing after the flush, so as the cistern fills it just runs straight into the pan. you'll need to replace the syphon...
Jul 07, 2011 | TOTO MS990CGR Neorest 600 One Piece...
I have a Neorest 550 brand new. It wont clear the bowl with any paper in it, and the nozzle seems very weak?
Tel: 1-888-295-8134
Aug 03, 2010 | Toto MS950CG-12 Neorest 500 Elongated One...
The bowl is full of water and cannot be snaked by a plumber it will not flush. it is a neorest 600
Be more specific.
JZ...
Dec 09, 2009 | Toto MS990CGR-11 Augusta Decorative...
Increasing water in bowl
You really can't because of the design. Any water above the level now will drain off. Sorry
Nov 04, 2009 | Toto Toilet Onepiece Neorest 600 ...
Toto Neorest 600 1pc. Toilet  MS99OCGR-01 Logo
27 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
