Question about Uniden TRU9280-3 Trio Phone
A epp fail message appeared on the phone
I unplug it for a day.
after plugging it again the phone has a message saying epp fail
Send message fail
wen i text any msg it doesn go it says messga send failed and resend from outbox and when i go to outbox and send it from there it says the same thing i need helpp pleasee anyone?
Oct 19, 2008 | Motorola Mobility C261 Cellular Phone
GE DECT 6.0 Model 28111EE2 is not working, registration failed message
I had the same problem, and restoring to default settings did not seem to work either. I just opened the back, unplugged the battery, plugged it back in, and now it works again.
Aug 26, 2008 | Uniden Cordless Phone
Brother 1840 bleeps
Try to unplug the handset and try again.
Unplug the phone cords from any shared devices.
Do you have DSL or any other digital type phone line?
Make sure the phone cord is plugged into the LINE port of the fax machine.
Jul 21, 2008 | Brother IntelliFAX 1840C Plain Paper...
Receiving picture message
please check with your wireless service...all the best
Happy to help
Have a nice day!
tc
Jun 02, 2008 | Sony Ericsson W850i Cellular Phone
Out of Range Message Won't go away
just contact your service provider (since you had the same problem when you bought a new set)...............the fault should come from their end.
good luck
May 13, 2008 | Lands Phones
"handset. No line"
Unplugging the phone will only fix the problem temporary!
Can anyone fix it for good? I am fed up of unplugging it every day.
No line... no line no line!
Stupid phone!
Mar 24, 2008 | Vtech Cordless 6041 Phone
Lx 300+ detected by xp but test page fails
hello,
please go to bios setting and change parallel port type spp+epp or epp or normal try to change type and try again.
Oct 14, 2007 | Epson LX-300 Matrix Printer
Display shows "Not Registered"
1. Remove battery from phone, and unplug from charging cable
2. Unplug Phone base
3. Hold Page button on base and plug it back in. While holding page button wait for in use light to go solid. Once solid unplug base.
4. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
5. Press 0
6. Unplug power from phone pod
7. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
8. Hold the page button on the base and plug it in, Hold page button until the in use light blinks. Let go of page button.
9. Press 9 on your phone. If it says Reg o it is finished. If it says Reg fail try again if it fails twice please call Tech support.
10. Replace Battery
11. Make a test call
Oct 05, 2007 | ClearOne Communications Max Wireless...
Uniden TRU9280-3 Trio Phone Logo
41 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
