Flashing H20 When i start a cycle the display flashes with H20 and doesn't appear to be filling with water. the machine is a hotpoint aquatltis aqxxf149pm
    Sniper:
  • 100 Answers
H20 means no water is getting to the machine. check your washing machine taps are on and water getting to the machine and the fill hose is not kinked.
Posted on Jan 28, 2009
My Indesit 7105 has flashing H20 lights, have checked but no blockages. It fills and drains fine, It wont agitate though, any ideas?
The machine does not fill with water or 'H20' flashes in the display.
The water inlet hose is kinked. • The water inlet hose is not connected to the water supply. • The water pressure is too low. • The water tap has not been turned on to allow water to flow into the machine. • There is no water supply to the house. • The inlet valve filter is blocked. • The START/PAUSE button has not been pressed.
Faulty pressure switch machine thinks there is no water in the machine.
Apr 01, 2017 | Indesit Washing Machines
What is code H20 on hotpoint washing machine
Check to make sure that the water valves are open and water is getting to the machine.
May 29, 2012 | Hotpoint Washing Machines
Hotpoint wt740. When starting a wash cycle the machine tries to fill but shows the H20 code and the water goes straight out of the drain tube (it appears to have normal pressure and flow rate).
Indesit (Hotpoint, Ariston) Error code H20
(Quote)'If the machine is not in the demo mode and this error is displayed it means there is no water being supplied to the machine.
To cancel press and hold start/cancel then press again to cancel the drain and the machine should now be reset and display 'ON' as usual.'(unquote)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 04, 2011 | Washing Machines
H20 keeps flashing
  • H20 - Not fillings. Check tap, hose and inlet valves
  • If you have proper water pressure the your water inlet valve on the machine is bad and needs replacing.
Dec 21, 2010 | Hotpoint Washing Machines
Hotpoint aqualtis giving H20 error, looks like fill problem, but cannot see anything stopping the water flowing into the machine.
i have hotpoint aqualtis, it washes & empties but then starts flashing when ready to rinse. any suggestions?
Dec 04, 2009 | Washing Machines
I have a hotpoint ultima wt940 washing machine,, which is displaying a tap symbol,, when it fills up at the start of the cycle,, h2o flashes on the screen,, then the machine stops. Any advice? Thanks.
H20 is indicating a problem with the water supply.
Check tap/s are turned on fully, no restriction in hose/s, and make sure that there is sufficient water pressure.
Another possibility is that the inlet valve/s are faulty inside the washer.
Please rate my solution.
Thanks.
Nov 07, 2009 | Washing Machines
My hotpoint washing machine will not wash and is flashing h20?
H20 is a fill fault. check water taps are turned on, inlet hoses are not kinked. if ok then a possible fault with the inlet valve(s).
Oct 30, 2009 | Electrolux Washing Machines
I have a hotpiont wf860 flashing fault code H20, please help
h20 code indicates that the appliance is not filling at all or filling to slow,check pipes are not kinked and taps are open correctly
Jun 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarious + flashing H 20 on display
H20 is indicating that you have no water coming in.
Check water is turned on,check hose(s) are not kinked, and finally check inlet valve.
If you are not sure if there is water to m/c, turn the tap off, disconnect the hose(s), and hold over sink and turn tap back on, water should come out, if it does not, then there is a prob with the supply.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Error code h20
hi sounds like a faulty fill valve easy fix
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
1,158 people viewed this question
Top Washing Machines Experts
