Question about Metz 58 AF-1 FLASH f/NIKON TTL Flash
METZ 48 af-1 N "err at the place where zoom value displays in LCD
I am having in problem with zoom part of flash,
plz help , otherwise it is firing well.
i purchased it new
  • Steve Draper May 11, 2010
    Is the flash gun set to your camera model.
    If so, the flash may be faulty. Take it to any good camera store and they may be able to fix it for you
Is seem a little bit strange but it worked for fine me
The problem is mechanical. The zoommirror in the flashhead is stuck. Mostly it is a minor opstacel. That is the reason that sometimes the problem is solved by placing new batteries. The zoommotor has a little bit more power en can overcome the minor opstacel.
When the zoom is blocked it cannot be controled by the stering software and therefore it gives an error.
Solution
1. remove flash from our camera (power off).
2. knok with something hard, I used my fingerknuckle, on the side of your flash head.
3. repeat that for each side (i knocked twice on each side).
4. place our flasher on the camera and power on both.
5. If the problem isn't solved repeat it
It worked for me the first time.
Posted on May 30, 2009
I have the same problem a few days ago. what i did was to give the zoom head a slight thug on with my palm. this will release the mechanism inside from being stuck. i think this is a slight mechanical problem with new metz flashes.
i have a 30D and a Metz 48 AF1.
peppermint-media.com
Posted on Feb 09, 2009
  • erik_belgium May 09, 2011
    I had the same problem, combining an Olympus with the 58AF-1.
    While reading the comments about the motor strength I had an idea: I replaced my normal rechargeable batteries for a moment with normal good quality AA cells.
    Because these are stronger the motor had enough power to overcome the problem...
    After removing the error I placed back the normal rechargeable AA cells.
    Erik from Belgium
SOURCE:
How to set metz 50 AF-1 flash off camera TTL to Nikon D800
There are many solutions, here is an example:
http://www.pocketwizard.com/products/cable_accessory/flash_sync_cables/
Mar 27, 2014 | Metz Cameras
I had metz 58 af for nikon mount can i convert it to canon mount
No. The Metz 58 is not designed as a part of a modular system.
Aug 10, 2011 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
I'm new to photography and have a Nikon D-50 with a Metz 58 AF-1 digital flash. Where can I find a users manual?
Metz 58 AF-1:
http://www.metz.de/fileadmin/fm-dam/Download/Photo_Electronic/Bedienungsanleitung/mecablitz/mecablitz_48_bis_76/mecablitz_58_AF_1_digital_Nikon_D_F_NL_GB_I_E.pdf
Nikon D50:
http://support.nikontech.com/app/answers/detail/a_id/13644
Sep 04, 2010 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
I have three new Metz 58 AF-1N's, and a Nikon
take a silver paper and put in front of the slave censer when you take the photo flash on camera as master should go on silver paper OR used slaveunit
Jun 30, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Metz 58 AF with Nikon d90 wont flash
Hi, Bad news for you.
Try this.
  1. put new batteries in flash.
  2. turn flash on off camera.
  3. listen for capacitor to squeal (high pitched whistle). If you hear it it is charging. If not capacitor is bad.
  4. Also should see flash ready light come on. If it does not same as #3 above.
  5. If you pass #3 & 4# above press manual flash/check/test button on flash. No flash means bulb is out. It can be replaced.
Hope this fixed ya. Please rate. Good Luck! Comment back if you need further assistance.
Mar 14, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Err at the place where zoom value displays in LCD
Though I am sure your solution may have been fixed already.
The guide that the reflector moves along for the Zoom.. has probably been knocked off position (either the guide/rail or the "runner" of the reflector).
Jan 26, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
External Flash for 3000Z
I have tried a couple of external flashes on the 3000Z. It is my understanding from reading various Internet posts (and I am sure someone will correct me if I am wrong) that, other than triggering the flash to go off, there is no communication between the external flash in the hot shoe of the 3000Z and the 3000Z itself. Settings need to be made manually in the manual mode to set the f-stop and the aperture to get good exposures. The Metz flashes are expensive. Most have opted to use less expensive flashes such as the Vivitar 283/383, or a Sunpak, or even a "Wal-mart" flash. I chose an inexpensive bounce flash with a secondary "fill-in" flash to get rid of the shadows sometimes seen with indoor bounce flash pics. I purchased the Phoenix 82ZBDA Multi-dedicated twin flash from Porter's Photo Catalogue for $37.95. This flash works fine, but is not that powerful (GN 79 ). If you need a more powerful flash, you might consider the Vivitar 383.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Open Questions:
Metz 58 AF-1 FLASH f/NIKON TTL Flash Logo
1,904 people viewed this question
Top Metz Cameras Experts
Doberman
TimHu
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Metz Camera Expert? Answer questions, earn points and help others
