Question about Sansui DTV3200 32" TV
New Sansui SLED 3200 won't turn on
We just bought a brand new Sansui SLED 3200 and the remote that comes with it is not working, we changed batteries, still no go. The manual knob to turn TV on won't work either. Support people are not available during weekend hrs! I can't believe it!
Pookeybrain
  • 51 Answers
SOURCE: 1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Posted on Nov 10, 2007
SOURCE: Sansui TVM1316
try channel 65 and connect via antenna cable.
Posted on May 30, 2008
  • 520 Answers
SOURCE: Sansui COM3101A 13" Tv/VCR Combo Problem
You can try the codes for Orion, Emerson, and RCA. Call the number on the back of the set to see if the original remote is available.
Posted on Oct 23, 2008
  • 520 Answers
SOURCE: New Sansui 27" and remote does not work
On later model Sansui tv's, you can bring up the menu by pushing both volume buttons on the front of the set at the same time. After the menu is on the screen, you can navigate using the channel and volume buttons.
Posted on Nov 04, 2008
SOURCE: manual buttons on set will only accept 3 channels
found solution by holding down both volume buttons at same time which enables on-screen menu allowing to select channel auto program
Posted on Dec 07, 2008
Bought a new replacement remote for my magnavox and it won't work??
It should be synchronized with TV using setup code. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 06, 2013 | Magnavox RC2033603/01 REMOTE CONTROL PART...
Won't turn on after unplugging sansui
Leave it plugged in for about an hour for it to warm up than it will work like normal. I have this problem every once and a while
Feb 02, 2013 | Sansui HDLCD3250 32 in. LCD TV
Audio somehow stopped working on my Sansui TV . I've tried resetting the tv, using both the cable and regular remote and I've went to the audio settings and tried changing things . I'm not sure what's
had a jensen that did the same so i bought a surround sound and hooked up through sat box hope this helps you save some money and get better sound
Jan 22, 2013 | Televison & Video
Sansui tv won't turn on
Check its main power supply regulator section circuit for defects. Check and replace damaged component/s.
Jan 10, 2013 | Sansui 32" TV
I used our remote to turn on the television and now it won't do anything.
please clarify set does come on with sound and brightness/picture or nothing happens when you turn it on--no flashing lights or lights lit?
the description is a bit vague, I presume its a Sansui and if so which model?
Dec 19, 2012 | Sansui 46" Widescreen 1080p Lcd Hdtv
I have a Sansui SLED 2280 that I'd like to use without cable input. How do I switch to regular over the air (no cable) antenna? Thanks
To switch from cable to air or vice versa on most Sansui flat screen tv's including the SLED2280, go into the menu. Select "channel" on the screen. Press "enter" on the remote. Select "auto ch mem" on the screen. Press "enter" on remote. Select "signal type" on screen. Press right arrow button or right volume button on remote to change signal type (cable or air). To program channels into tv, select "automatic search" on screen then press "enter" on remote. Wait for search to finish.
I hope this helps you.
Bobya
Dec 19, 2010 | Sansui Televison & Video
In sansui television. is not working properly. in the remote. but front panel is working. i have changed the remote also . but problem remains. then i changed the sensor. it remains. then changed the...
dear,i also had suffer from it's service menu code. in some days ago i had been seeing a web site, their was had every service menu.then i got your sansui tv model.your sansui "ctvk2k21"model's in the IC no. is "tda9370ps/n3/a/1932" service menu is press "menu(from remote) & 0,3,2,3(from remote)".for more information call me for in any electronics gagged problem.
Aug 15, 2010 | SansuiM1315 TV
Sansui VRDVD4000
Universal remotes rarely fully work with these type of units. Call Orion customer service 800 289 0980 to price an original remote.
Oct 09, 2008 | Sansui VRDVD4000 DVD Player/VCR
Sansui DTV3200 32" TV Logo
98 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
