Question about Leviton Decora Light Dimmer Switch
How to stop flickering in cfl light using illuminated 3way switches
4 Suggested Answers
SOURCE: I replaced my old 3way
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=4044§ion=10103&minisite=10025
The Leviton page for Leviton 5613 does not have a troubleshoot.
Manual shows simple wiring diagram.
3-way switches will not operate lights if switches are wired incorrectly.
Check your ground wire is connected.
Leviton 5613 series is illuminated.
Check that both switches have 5613 number.
Swap switches and see if problem is inside switch.
Posted on Nov 14, 2010
SOURCE: I installed the motion sensor
Leviton manuals:
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=17219&minisite=10022
A quick peek inside a sample Leviton manual confirms that your wires are connect correct - BUT...
http://waterheatertimer.org/pdf/Leviton-motion-Instructions.pdf
The remaining 3-way switch needs a jumper wire.
See if your instruction manual shows the same thing as image below.
Let's go through this.
The yellow wire connects to a traveler ... and that traveler connects to one of the brass screws on 3-way switch.
The black wire from Motion sensor also connects to a traveler wire ... BUT you have to identify which traveler wire and which brass screw that traveler wire connects to. And then, put a jumper wire (a short piece of wire) from that brass screw to the dark-colored screw.
I think that will do it.
Add a comment if your device is different.
Some of these electronic devices are reversed when two of their wires are connected together.
That's what the jumper wire is doing. So the 3-way switch is just connecting and disconnecting the black and yellow wires, and that action reverses the circuit in the motion device.
Posted on Nov 23, 2010
Blue Dog
  • 75 Answers
SOURCE: I installed a Decora white
Sounds like a problem with the fixture, not the switch. I'd say replace the ballast, or just replace the whole fixture.
Posted on May 08, 2011
When a CFL burn it flicker after 2 or 3 sec how to remove it.
Is the CFL new? If not then it may be lacking sufficient
gas to keep it ignited. Start by replacing bulb.
Dec 15, 2013 | Cooper Lighting Lighted Switch
Tip
4 way switch
If you wish to control a light or lights from more than 2 places, then you need a 4 way switch in between the 3way switches. You can use any number of 4 way switches in a lighting circuit.
To rough wire the switches, run a 3wire with ground cable from the 3way thru the 4way(s) to the other 3way. As in the 3way switch wiring the light and power can be at either end, that part does not change.
The diagram for the addition of a 4way switch looks like this..
The travelers from the 3way switch connect to like colored screws on the 4way .. If more switches are wanted, just add them in the center of the circuit in the same manner as the first 4way .
on May 14, 2010 | Hammering
Ceiling fan lights flicker in bedroom with 23watt cfl bulbs
Sounds like an older unit that has either a dimmer or electronic switch. You need to use dimmable CFL lamps.
Nov 07, 2013 | Hunter Dryers
I replaced my old 3way toggle switches with the LEviton 5613 3way lighted rocker switches. Wired exactly the way the older toggle switches were wired. Switches work fine just like the older ones but one...
Nov 13, 2010 | Leviton 5613-2WSP Grounded Switch
Compact fluorescent flickers when the switch is off.
You could be getting power from the source in the switch ... does this flickering occur with a non illuminated switch? Have you tried the CFL in other sockets? Have you checked the socket in question for proper polarity? (Hot wire should be broken by the switch and that hot wire should be connected the bottom of the CFL in the socket). Does your switch have a white wire for the neutral connection or are you using the ground wire to illuminate the switch ... or is there a different lind of light in the switch and/or do you know?
Normally ... let me say again ... normally, (in a traditional sense) an illuminated switch should have a neutral connection, a ground lug and the expected 'in' and 'out' for the switch leg. Normally, I would expect the switch leg to use a black from the power source (normally found in the box where the socket is mounted) and a white from the 'off' side of the switch to the socket.
I tried to draw you a diagram ... but it didnt work out and you probably already get the picture.
If everything checks out ... and it still flickers, replace the switch with a non-illuminated switch or use a incadescent light until they are no longer available.
Thanks for your interest in FixYa.com
Jun 21, 2010 | Cooper Lighting Lighted Switch
I have a hampton bay ceiling fan. I put cfl bulbs in the lights and when i turn the lights off using the remote the bulbs continue to flicker. when i turn the wall switch off the bulbs stop flickering. the...
The problem is that the CFL lamps, once they are lit, will stay energized by a very low level of current, and the remote obviously is not what we would call a positive off device .. if you use the wall switch and then go back to the remote in the off position , do the lights come on flickering again? You could try another brand of remote.
May 19, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Lights flicker on ceiling fan: We have 4 cfl bulbs in a ceiling fan light fixture that have recently started to flicker. They've been there for a while without the problem, so it's not a matter of a new...
It is not a ceiling fan or wiring problem. It is your bulbs. Normal CFL bulbs do not work in dimmers or with remotes. Remotes work on RF signals and cause interference with the bulbs. You may also notice a buzzing sound and the lights may not go out when you turn off the switch. It is a fire hazard, can invalidate your warranty on the bulbs and will shorten their life. Try changing the bulbs to the new dimmable CFL's and see if it helps. It should eliminate your problem altogether.
Mar 15, 2010 | Hampton Bay 52 In. White Redington...
New Leviton 'lighted, decorative' switch flickers when off
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
May 31, 2009 | Leviton Decora Light Dimmer Switch
Hampton bay CFL lights flicker when they are turned off
I believe the flickering comes from the way the CFLs extinguish themselves after the remote turns them off. As the other poster said, turning them off with the wall switch as well after turning them off with the remote stops the flickering.
It is because the remotes are a dual mesh type of signal, which uses the RF as well as the electrical power to activate and turn them off.
Actually, this type bulb is not designed to work as well in dimmers or remote switches as is incandescent. You will find if you replace them with regular incandescent they will not flicker.
Sirwriter
Apr 13, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Lights flicker when turned off by remote
I had this same problem with a Hampton Bay fan with a remote light switch. I call the manufacturer of the of the switch and was told that the model switch I had would not work correctly with CFL bulbs. The problem is with the dimmer function. You either need to change the bulbs to incandescent, or change the remote receiver in the ceiling. Hampton Bay was kind enough to send me a new receiver that works with CFL. The CFL units are white, and the incandescent is black. Hope this helps you.
Feb 26, 2009 | Universal Remote Control Hampton Bay...
Leviton  Decora Light Dimmer Switch Logo
168 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
